GiveMeABreak wrote: ↑11 Feb 2020, 12:18
So there are 2 water temp. sensors - the Green one in the water outlet housing and the blue one under the Cylinder head:
With respect to the fan being triggered if temperature exceeds 105d with engine turned off, is this operation triggered by the temperature value from the Blue or Green sensor.
My understanding is that when the engine is running, the fan low speed is triggered when the temperature value from the green sensor reaches 97d and the fan high speed and STOP warning light are triggered when the blue sensor temperature value reaches 118d. If this is the case, would I be correct in assuming that the post cooling @ 105d is triggered from the blue temp sensors value via the ecu?
I can now recall that prior to the HG being replaced that the low speed would engage at 97d and when the temperature soared the high speed and stop warning lights on the dash would engage around the 115 -118d mark, but I could never recall the fan engaging when the engine was turned off and temp was above 105d.
Presuming that my temp sensors, ecu and fans are working as they should be when engine is running, could the fan speed resistor be the reason that the post cooling is not engaging?
