Bargain Basement Electric
x 7084
Re: Bargain Basement Electric
The weather this week so far has been cold and wet, small sunshine breaks. Today decent enough daytime forecast to around 5.00 pm ish but still pretty cold.
Spotted this very yellow field and a brooding sky but the light was tremendous. Just right for some brochure shots of the BB Leaf.
You can in a Nissan
You can in a Nissan
x 7084
Bright blue sky to the right, brooding clouds to the left
x 5164
Had a rather busy afternoon, no pictures but we have had brilliant sunshine, dark clouds, snow and thunder and lightning in several rotations.
x 6559
Having found our 3 in 1 tree I thought a brochure shot or two was in order:
Own work
Own work
Own work
Own work
Mandrake
x 692
Unread post by Mandrake »
NewcastleFalcon wrote: 27 Apr 2021, 17:56 So today saw the first charging up session using the "granny charger" with the 3 pin plug chugging along for 4 to 5 hours to take me back up to my customary 80% state of charge.
Its done its job, and for now that is going to be the normal charging up routine, consuming household electricity at 16p/kWh.
Smart Meters/ Smart Home Charging points may get you 5p/kWh from Octopus but for now the home fuelling is going to come through a 3 Pin plug :-D
If you don't do a high mileage, technically you don't need a smart charger or any charger other than the 3 pin charger to take advantage of night rates like Octopus's. All you need is a smart power meter.
The car itself has a charge timer that you can configure start and end times for your charging. I already use the timer on my car without a night tariff - I set the charge end timer to 7am Mon-Fri and leave the start time empty. This causes the car to automatically start charging as late as possible to reach 100% at 7am, so typically it starts about 3am. If you have a specific time window you would use a start timer instead so that most of the charging happens during the cheap time.
The charge timer only affects AC charging not Chademo, however if you do want to override the timer and charge immediately on AC you just press the charge timer override button on the dashboard before or after you plug in.
The only problem with night rates using the 3 pin charger is that you'll only fit about 8kWh worth of charging into a 4 hour time window using the 3 pin charger, or about 30 miles of range. If you want to fit all your charging into the cheap time window you'll need a proper charge point that can charge at the full 6kW.
I'm strongly tempted to get a Smart meter and switch to Octopus myself as at 6kW I could easily do all my daily charging during the cheap night rate period and cut my charging costs to a third of what they are now. :) Only the morning defrost would come out of the normal daily rate - but even in the middle of winter that doesn't amount to more than about 1.5kWh, and their day rate is slightly cheaper than my current provider anyway!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 7084
Mandrake wrote: 11 May 2021, 09:52 I'm strongly tempted to get a Smart meter and switch to Octopus myself as at 6kW I could easily do all my daily charging during the cheap night rate period and cut my charging costs to a third of what they are now. :)
Yes, I think its only inertia which stops me organising a smart meter. Gateway to cheaper tariffs. We were all set to have one (Scottish Power) but lets say a bunch of inexperienced installers, turned tail and claimed they couldn't install it as the DNO's main fuse was "fragile" and likely to break if they tried to remove it.
x 5164
SP keep nagging me to install smart meters. I continue to resist. They have just refunded me a not inconsiderable amount this month.
x 7084
Had we hung around for a few more hours we would have had a chance to meet the cast of Top Gear who were apparently going to do a bit of filming for a future episode, driving around in EV's. That's a 7kW charger so if they rocked up in Tesla's Audis and Porsches they would have had to have a very very long lunch to pump some extra miles into their large batteries :-D
One of the more scenic charging points on the A68
x 7084
Sunshine and Showers<br />Northumberland does brooding skies pretty well
x 6559
So does Hertfordshire, a perfect backdrop for my friend's Acer:
Own work
Own work
x 7084
There's me thinking the Acer was a car model....its the bush of course :-D
There was definitely a bit of dramatic lighting over the countryside today. Wind turbines looked particularly white when lit up by the sunlight against the dark Skies, and the fields and trees coming into leaf were vibrant.
x 6559
NewcastleFalcon wrote: 19 May 2021, 18:58 There's me thinking the Acer was a car model....its the bush of course :-D
Indeed his is a DC Acer (Directly Cultivated) not an AC Acer !! :lol:
x 7084
The Car in front is a Nissan<br />The Car Behind is one of Citroens More Colourful and interesting offerings of recent times.
x 7084
you can with a Nissan
View from the East Coast's finest carpark
Homeward Bound in the Evening Sun
dave
x 17
Unread post by dave »
NewcastleFalcon wrote: 22 May 2021, 19:31 Image
the only catus with the pricks in the inside ?
