DS4 heater blower
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5741
Re: DS4 heater blower
Post by GiveMeABreak »
It shouldn't be too difficult, just get some trim removal tools:
Using trim removal the tools, unclip:
Clip (at "b")
The trim (1) (at "a")
The diagram shows a left hand drive, but is a symmetrical operation on both sides.
Munch ATG
My Cars: 2013 DS4 (daily driver)
C3 Picasso (mothers taxi)
BMW 420D (a little something for the weekend)
Post by Munch ATG »
Ace. Thank you
Munch ATG
Post by Munch ATG »
Hi guys, quick update. I conducted a quick experiment, and it worked! I closed all the vents in the car, turned the heater on manual and up full, then blasted down the central air vent with a blow gun from my compressor and hey presto the fan spun up! No trim or motor removal necessary. Dont know if this will work for everyone but its surely got to be worth a try! Peace ✌
C15 Romahome White
CX 20 Polar White
x 5741
This is what can happen - the motor bearings can stiffen up with water condensation over time - and as the blower motor resistors are only designed to slowly spin up the motor, they have insufficient welly to get the motor going. A temporary direct shunt on full power (bypassing the resistor temporarily) will often kick start it, but you'll find this may happen again and again.
On a homeward bound journey it may be helpful to turn the climate control up to a warmer / hotter temperature for the last leg home and that may help keep the heater unit warmer and reduce condensation, but ultimately it may require a blower motor unit replacement at some stage when it gets worse.
Munch ATG
Post by Munch ATG »
Yeah, had figured it was only a temporary fix but I will take it as a win for now at least! I also have my trim removal tools now so when it does die for good I'm all set for the replacement of the motor. Peace
Munch ATG
Post by Munch ATG »
Good morning. Have a new problem now, I have noticed that whilst I can get the heater to spin up on manual, as soon as I switch it back onto automatic it just shuts off. Could this be something to do with the control resistor? Peace
C15 Romahome White
CX 20 Polar White
x 5741
Don't forget that with Automatic Climate Control the fans don't necessarily speed up on maximum straight away - it is usually a staggered approach, reaching the desired temperature settings gradually as the system is able to comply using engine temperature and air heating resistors to achieve this (in the case of warmth) as nothing is served by putting everything on full blast.
So on AUTO mode, you can try setting the temperature controls to a setting one above the lowest or one setting under the highest (because setting the temperature dial to HI or LO maximums disengages climate control) and then see if after a while the fan speeds start to increase over 5 minutes or so. Of course this will all depend on the outside ambient temperature and the perceived cabin temperature as to how long it will take (as it is not physically measured). But you should be able to hear the gradual increase in fan speed as the system compensated and adjusts within 5 minutes or less.
Jevjev25
New User
My Cars: Citroen ds4
Post by Jevjev25 »
Hi it’s been really cold and icey today when I first started the ds4 the heater fans was working then I stopped it too pop into the shops then nothing no fan spinning I going too pick up a multi meter in a minute as I need one anyway where should I start eg where’s the fuse and if that’s fine where should I go from there
Kind regards jevan
Blowers
My Cars: Citroen Ds4
Post by Blowers »
Hello, I have an issue with the blowers not operating correctly into the cabin.
I can feel a tiny bit of air coming through when it's set to maximum and that's about it.
The dials on the panel all seem to be working. When I try to adjust the fan speed I can hear a slight electrical sound (removed the trim already).
Should I change the Blower control module first?
Where is this located on a 2013 DS4 1.6 Diesel?
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3008
Post by Hell Razor5543 »
Hi, and :welc: to the Forum. Before changing any parts you might (if you have not already done so) check the status of the pollen filter. I have heard of them getting so clogged that even a tornado would struggle to blow through it.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
C15 Romahome White
CX 20 Polar White
x 5741
Blowers wrote: 17 Aug 2021, 15:43 Hello, I have an issue with the blowers not operating correctly into the cabin.
See my illustrated post here:
viewtopic.php?p=662328#p662328
C15 Romahome White
CX 20 Polar White
x 5741
No it's not. :wink: The actual Blower Motor itself is completely separate. This is about the Heater Blower Control Module which is what it is officially called. This is the electronic module that contains resistors that spin up the motor.
As condensation / moisture gets into the actual blower motor, it can cause the bearings to become seized. Because the Blower Control Modules are designed to spin up from zero slowly, they can struggle when the former condition is true, so they often don't have enough initial power to get going. Of course the blower control modules can fail too.
But as per my diagram in Post 14, item (3) is the Blower Motor Control Module location.
A word of caution - if replacing the module, don't be tempted to get a cheap unbranded Chinese one or one from ECP. Get a decent branded Behr, Valeo or OEM one if you can.
lisasherratt
Donor 2023
My Cars: Ds4 1.6 petrol 200thp
Post by lisasherratt »
Thank you, hopefully we will be able to replace it and make it work again.....
Yitearp
My Cars: Citroen DS4. Renault clio 1.8 VT
Post by Yitearp »
Hi folks,
Was directed to this thread from my own here: viewtopic.php?t=71201
Is there a parts number for this item so i can get start the process of looking? Given the details in the thread i am to assume the module needs replacement and it is not a fuse?
Thanks in advance
C15 Romahome White
CX 20 Polar White
x 5741
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Post Reply
