I didn't put up a diagram Kenny, but here is the suspension ECU diagram if you need it:
7715 is the suspension ECU
C001 is the Diagnostic Port
9009B is the wire I referred to on pin E2 for the diagnostic
Splice | Wire No. | Connection 1 | Instrument Reference | Connection 2 | Instrument Reference |
E909 | 9009 | Diagnostic Connector | C001 | E909 | - |
- | 9009c | E909 | - | ESP ECU | 7800 |
channel matching |
1 ignition positive |
2 not used |
3 diagnostic CAN H - BSI |
4 body earth |
5 electronic earth |
6 Intersystem CAN High |
7 fault-finding line K - engine management - automatic gearbox - additional heating |
8 diagnostic CAN H - BSI |
9 not used |
10 not used |
11 not used |
12 fault-finding line K4 - ESP - hydraulic suspension |
13 not used |
14 Intersystem CAN Low |
15 not used |
16 battery +ve |
