Has the time finally come for a DS3 Racing engine rebuild??
x 350
Re: Has the time finally come for a DS3 Racing engine rebuild??
Post by xantia_v6 » 01 Oct 2019, 07:57
notrix wrote:
30 Sep 2019, 21:58
So I did a compression test today.. I got about 185psi or just shy of 13bar across all the cylinders.. seems a bit high heh??
I would put the brakes on here, just a little.
I think that it is more probable that your compression gauge is inaccurate than all cylinders have an abnormally high compression pressure.
If your compression pressure was really too high, then the engine ECU would be throwing knock and super-knock fault codes all the time.
I am not aware that these engines have any history of carbon build-up in the cylinders themselves, just in the inlet ports, which is a different set of symptoms.
I think that all of the symptoms that you initially listed could be caused by a failed PCV valve, or perhaps by bad turbo seals allowing an abnormal quantity of oil into the engine.
notrix
Post by notrix » 01 Oct 2019, 11:29
I would like to try and diagnose the PCV system. I have the OEM PCV blanking caps lying around (OEM part #0361.S4). Do you think installing these would help me diagnose a faulty PCV valve? The caps are for blanking off the rear PCV connection between the rocker cover and the intake manifold.
x 350
Post by xantia_v6 » 01 Oct 2019, 14:06
Yes, fitting those caps blocks off the rear PCV valve (the one that I suspect has failed), and with that blocked off, it does not matter if the front PCV is leaking, as there is no source of suction to suck excessive fumes from the crank-case. In fact on my car (which has a good vapour separator fitted), I have left the front PCV valve open, so prevent the slight pressurisation of the crankcase that can encourage oil leaks.
With the rear PCV blocked off, any blow-by past the piston rings will come out the front breather and be easy to detect (there will normally be some, but not an excessive amount at idle.
notrix
Post by notrix » 01 Oct 2019, 14:48
Ok.. I'm a bit worried about possibly increasing the cranckcase pressure if I fit the caps but I guess for testing purposes it should be ok. I'm gonna install the catch cans I have soon but I need to figure out if the rear PCV system has failed anyways so..
x 350
Post by xantia_v6 » 01 Oct 2019, 14:58
Any positive pressure in the crankcase is vented via the front pcv valve to the turbo input, as it always was when the engine is on boost.
For test purposes I would leave the front pcv hose disconnected so that you can see how much vapour is ejected.
notrix
Post by notrix » 01 Oct 2019, 15:03
Allright.. Cheers. I'll try that :)
notrix
Post by notrix » 03 Oct 2019, 22:28
I just installed the rear PCV blanking caps. No difference regarding the rough idle. I filmed a short video of the front PCV hose after blanking off the rear one. Of course I forgot to check how it was before :?
Here's the clip;
If you're on a computer sorry for the aspect ratio :lol:
Reason: YouTube link
Nemo26
x 3
Post by Nemo26 » 05 Oct 2019, 20:26
I've seen high pressure fuel pumps failures in the way that the fuel leaks through them in oil line. Remove crankcase pipe and block the hole to engine temporary and check fuel trims before and after. You'll see improvement. Fuel evaporetes from oil sump and creates rich condition, there is basicly one more fuel source and that is fuel vapour from oil sump which goes trough crankcase breather pipe in intake manifold. Ecu tries to compensate and cuts flow trough injectors (rough idle).
notrix
Post by notrix » 06 Oct 2019, 12:24
Nemo26 wrote:
05 Oct 2019, 20:26
Thanks for the tip. Do you mean that fuel could leak from the pump internally in the engine block?
Nemo26
x 3
Post by Nemo26 » 07 Oct 2019, 04:34
Yes, hp pump is lubricated with engine oil.
notrix
Post by notrix » 11 Feb 2020, 22:29
Nemo26 wrote:
07 Oct 2019, 04:34
Sorry for the delay.. The car is stowed away for winter storage so progress with trying to diagnose the problem is currently slow :-D
I've done some more research into the high pressure fuel pump and it seems the only way it could leak fuel into the oil would be through it's connection to the camshaft. I have read about several cases where the HPFP has failed on these cars but can't seem to find any cases where it has leaked fuel into the oil. Today I checked the fuel rail pressure and it seems normal both on idle and at a steady 4000rpm. Given the amount of problems with the original version of these pumps I'm tempted to replace it anyway but I'm suspecting the real problem lies somewhere else..
citroenguy
x 11
Post by citroenguy » 12 Feb 2020, 09:05
I'd say you need to get the valves blasted ocr cleaned, i suspect the rough idle is because of carbon buildup whitch is common on these.
And also get the latest crank case ventilation/vevhusventilation parts .
You never know but i doubt there will be any piston/ring damage at this low of a mileage, and this engine isn't known for that either.
notrix
Post by notrix » 12 Feb 2020, 12:29
citroenguy wrote:
12 Feb 2020, 09:05
Totally agree.. what has me dumbfounded though is why such amount of gas seemingly ends up in the oil pan..
Sharkie
Post by Sharkie » 14 Feb 2020, 20:30
Lots of cold starts, bad spray pattern or just regular use. Or overfueling the engine.
Some fuel in oil is normal.
