Did you solve the starting problem?
Can I have a wiring diagram please ! Xantia
- white exec
- ksanturion10
- My Cars: Xantia Estate X1 1.8i, 16v
- x 19
Re: Can I have a wiring diagram please ! Xantia
I found some inconsistencies into the first posted set of wirings . If the M2A, M2B and M2C earth points represent different mounting locations (different bolts screwed onto the gearbox) and not different earth cable ends, there must be a mistake into the 3-rd diagram from the same set, which shows points M2A and M2B sharring one and the same location over the gearbox! For example take a look at the second posted wiring set by xantia_v6.
BR
Martin
BR
Martin
Only himself the stupid makes wrong, many are being confused by the clever
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 833
It is possible that there are errors in the diagrams, although this would be quite rare, as the schematic and harness diagrams were probably generated from the same CAD files that were used to produce the actual harnesses (this is evidenced by a wire for the low coolant warning that is missing on the diagrams for 1997 Xantia 2.1 and V6 diagrams which is also missing from the harness!). I think that the location diagrams are more manually drawn and more likely to be inconsistent.
As there were several changes in the wiring during Xantia production, you need to be careful in interpreting any of the diagrams.
