Peugeot 207 ABS pump
Re: Peugeot 207 ABS pump
Thanks Marc, just one more question when I get the part will I have to take it to a Peugeot garage for them to recode it.
- x 2245
If you get the exact part number (either the peugeot part I provided) or a matching '96******' number is should not need to be coded as 4541Z3 is for your vehicle with all options as it left the factory.
Brilliant, thanks again Marc will definitely let you know how I get on.
Hi I have been through this abs swap with my 2006 207 1.4L What year is yours?
I first got a duff one from eBay that didn't work, swapped ECUs etc.. and then paid 60 quid for a tested used one from ebay that actually did work, but I had to recode with the scantool. The coding is not to the individual car, but just model tyre size.
I don't envy your mechanic it's a complete hell of a job to fit, it took me 5 hours, and then I had to bleed the brakes the next day. The soft aluminium of the abs unit can be easily cross threaded by the steel brake union threads. The trick is to get a old union and retap each thread when this happens. The access to tighten them is also next to impossible, a few mms.
Hi Marc, as promised i’m back with an update.
Managed to find the part through 1st choice website & it worked. My car has now passed it’s MOT & Im back on the road again. Thanks again for all your help.
- x 2245
Excellent news! Thanks for the update - this will surely help others in the same boat and I'm glad you're back on the road again
- Donor 2020
- x 54
Well Done Shaz61Muscleriot wrote: ↑28 Sep 2019, 21:31..... but I had to recode with the scantool. The coding is not to the individual car, but just model tyre size.
Hi skull, I got the exact part as advised by GiveMeABreak & confirmed with my mechanic that no coding was required. Hope this helps
- Donor 2020
- x 54
Many Thanks Shaz61
- x 2245
- Donor 2020
- x 54
GiveMeABreak Master in the Dark PArts
- New User
I need a replacement ABS pump for my Peugeot 207. I am unsure of the correct ABS pump number though. Please see VIN below.
VIN no. - VF3**************[VIN obfuscated, can be read by forum staff]
- x 2245
MOre than happy to assist, but PSA now charge for live parts information. See info below. A £10 donation will cover you for parts info and parts diagrams for up to 2 years.buckedrelic257 wrote: ↑03 Sep 2020, 16:07I need a replacement ABS pump for my Peugeot 207. I am unsure of the correct ABS pump number though. Please see VIN below.
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
