Citroen Owner Handbooks
Locked
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5721
Post by GiveMeABreak »
If you don't have your Citroen owner's manual, you can view most of them online or in most cases download a copy as a PDF, or in some cases just the relevant section required.
Not all early models are included.
  • Just follow the link, select your preferred language from the top right corner
  • Then select the model
  • Now select the car image and finally the build date of your vehicle
These are searchable for content, and if they are available as a download, there should be a PDF icon shown. Click on this and it will either give you the option to save the file, or will open in a browser window. Once the file has loaded, you can save the file as a PDF to a location of your choice.
Bear in mind some of these can be 400+ pages for some newer models with loads of options, so may take a little while to download for some users depending on your broadband speed.
Citroen Owner Handbooks Link
Note: These are Owner Reference Handbooks for the Equipment and Operation - not Mechanical manuals.
Locked
