Silly thought.
Donor 2020
x 711
Re: Silly thought.
Made a start on this yesterday, it's not going well, sun beating down on my back, rounded screw heads, clips that won't unclip, brittle plastic pipe snapped.
Now it's peeing down with rain and looks to be set in for the day :(
Michel
x 327
Re: Silly thought.
Unread post by Michel »
Gibbo2286 wrote:
30 Jul 2019, 09:30
Sounds like a normal job on most Citroens..
van ordinaire
Donor 2017
x 240
Re: Silly thought.
That's cheered me up no end, I'll stop winging now about the huge lie that C15's are easy to work on.
Donor 2020
x 711
Re: Silly thought.
Compared with this Van the C15 is a doddle. :) It's stopped raining now so off back out to finish the job in a few minutes, well after breakfast.
van ordinaire
Donor 2017
x 240
Re: Silly thought.
Well, of course, all things are comparative but no vehicle has defeated me as often as the C15 - although I'll concede the starter is easier than most.
Donor 2020
x 711
Re: Silly thought. Broke it!
Got the thing all back together, fired it up, it ran for a couple of minutes then stopped and won't start again, eml is on and the diagnostics says 'pre-post heating sensor fault, not connected' . :shock: where the hell is it located.
Checked the glow plugs and they're all reading ok now and I'm sure everything that came off (connections) has been put back on.
x 1945
Re: Silly thought.
Glow plug relay....
The relay is on the right shown as 1158
Donor 2020
x 711
Re: Silly thought.
Thanks Marc I found it hidden away under the damned BSI I might take it apart and see what's going on in there.,
x 1945
Re: Silly thought.
It should be near the engine fuse box, usually off the left side, it won’t be in the BSI which is in the glovebox Eric.👍
Donor 2020
x 711
Re: Silly thought.
So here it is and at Neil's request the old glow plugs the one with the blue mark is the only one that works.
Also the relay which I've opened to show the innards, can get the points to close by connecting direct to the coil but otherwise nothing, new one ordered so I hope that's a fix.
x 967
Re: Silly thought.
Thanks Gibbo I like a picture or two. I may be following the same route myself with the Vectra, if my newly fitted glow plugs fail to spring into life. While glow plugs are not really needed for starting these days except in the most arctic of conditions, I do believe that the glow plugs could require to be operational in a regen, and a fault in the glow plugs/relay leg could stop the "computa" either initiating or completing a regen.
Maybe someone with greater knowledge of me on the C5 could confirm whether this is the case.
My little task on the Vectra has been to sort out an incompleted regen on the DPF. About to put it all back together after replacing the glow plugs and the downstream Exhaust Gas Temperature Sensor, giving the DPF the hose pipe treatment, and checking out the pipework to the pressure sensor.
Physically everything seems ok, but if one part of the sytem is not working then it blocks a regen of the DPF taking place. On the Vectra its as rudimentary as DPF systems go but whether the "computa" still has its knickers in a twist thinking that it is still stuck needing a regen even though it doesnt time will tell.
Donor 2020
x 711
Re: Silly thought.
I'm just hoping that the relay is a fix for the non-starting, not 100% sure. :(
I can't understand why it started first time after I put it back together then stopped after a couple of minutes.
x 1945
Re: Silly thought.
NewcastleFalcon wrote:
02 Aug 2019, 11:41
....While glow plugs are not really needed for starting these days except in the most arctic of conditions, I do believe that the glow plugs could require to be operational in a regen, and a fault in the glow plugs/relay leg could stop the "computa" either initiating or completing a regen.
The pre-heater plugs enable a rapid rise in temperature in the combustion chambers during the starting and cold-running phases.
The pre-heater plugs are also used for depollution, contributing to the reduction of nitrous oxides and soots.
There are 4 modes of use for the pre-heater plugs:
  • Pre-heating
  • Pre-heating under starter
  • Postheating
  • Postheating for regeneration
Although the Glow Plugs can be used in regeneration it is only at the request of the engine ECU if deemed necessary to load the engine - and then only for a short period (1 second max.). Whether they are activated or not in this case depends on the engine speed and fuel flow, otherwise there is a risk of knock / over heating. So they are not used as a matter of course - only if needed and briefly at that.
x 967
Re: Silly thought.
Thanks Marc,
So not part of a pre-regen "test" by the ECU to establish that all components potentially required for a successful regen are in order. If the circumstances arise that the ECU does make a call to the glow plugs during a regen, and they are not working, presumably it records some fault code, but the regen is not stopped.
x 1945
Re: Silly thought.
The ECU can employ various strategies to try and complete any failed regeneration attempt because of various reasons - but it can also activate the heated rear window to increase system load for example. These are most likely to be employed in the cases of shorter trips where the engine is not up to operating temperature or regeneration is constantly interrupted. If it can't regenerate using any of the strategies it will flag up the 'Risk of Clogging' warning to get you to go on a long enough drive to complete a regeneration.
Let's not forget that the fuel injection also plays a part in the post injection process to assist with emission control and DPF regeneration.
