Buying a Xantia with 2.0 HDI engine. What to look?
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: Buying a Xantia with 2.0 HDI engine. What to look?
There is cable adjustment on the accelerator which may put the pedal at a more comfortable height if you introduce a little slack.
I remember finding the xantia very uncomfortable at first. In my case, I thought the car was designed for people with short legs and long arms, as i practically had to climb out of the seat to reach the gear lever, sometimes.
I could raise the seat, thus bending my knees and moving myself a bit closer, but then my head was touching the ceiling.
I can't say I ever "solved" the problem, but I certainly grew used to it and was very happy to drive Holyhead to Hastings in one go, with no discomfort at the end of the drive.
If your problem is only with one leg, I suspect moving the seat won't be the answer.
Try adjusting the pedal, first. Someone may have fitted the throttle cable incorrectly
Sparksie
2000 Xantia 1.9TurboD
