Failed to proceed!
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2500
Re: Failed to proceed!
Post by Gibbo2286 »
mikeyb1949 wrote: 13 May 2019, 17:50
wheeler wrote: 13 May 2019, 16:17 If you take the plug off the tank unit there will only be 2 terminals on the tank unit (not the wiring loom) if it is just a sender & 4 terminals if it a combined pump/sender.
Yep, 4 terminals on mine.
As I said earlier from your photos it's clear that yours has a pump, here's a picture of the actual pump but it's still a mystery because all the Citroen literature says it should not on that model or with that VIN.
This advert though offers it for your engine (and my) type.
https://www.auto-sensors.co.uk/citroen- ... 172-p.asp
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 825
Post by xantia_v6 »
I note that your send unit has a beige top and looks very clean, both of which would indicate that it is not the original unit.
Having a pump installed in a system which did not originally have one does not explain why the engine now will not start, but does explain why primer bulbs occasionally explode.
Perhaps there is something else in the circuit before the high pressure pump that has become dislodged or malformed with the unexpected pressure and is now causing a blockage?
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5644
Post by GiveMeABreak »
I'm wondering if it is actually used or powered - they may well have fitted these to use up stocks from the DW12TED4 models.... but certainly the VIN states without pump and that is what you would get from the dealer if booking in for a replacement.
x 2500
Post by Gibbo2286 »
GiveMeABreak wrote: 13 May 2019, 18:38 I'm wondering if it is actually used or powered - they may well have fitted these to use up stocks from the DW12TED4 models.... but certainly the VIN states without pump and that is what you would get from the dealer if booking in for a replacement.
But the op does say earlier that it pumps when he switches on with a pipe disconnected so it must be powered.
I'd guess that it's a replacement pump from somewhere that doesn't know the difference.
C15 Romahome White
CX 20 Polar White
x 5644
Yes I’d agree with that and as Mike says it looks too new to be original
mikeyb1949
My Cars: 2006 Citroen C5 Estate 2.0HDI
Post by mikeyb1949 »
Just been talking to my son (remember it's his car) and he tells me that (unbeknown to me) he replaced the sender/pump unit last year. Car stopped and AA patrol told him that the fuel pump had burnt out. He replaced like for like. Ran for several thousand miles until recent problem. Still don't know of course if this was as per original build. Mike.
Dibber
My Cars: Citroen C2 Furio
x 4
Post by Dibber »
Might be worth posting some pics of the engine Mike. Maybe other members can do comparisons to their own.
C15 Romahome White
CX 20 Polar White
x 5644
mikeyb1949 wrote: 13 May 2019, 21:21 Just been talking to my son (remember it's his car) and he tells me that (unbeknown to me) he replaced the sender/pump unit last year. Car stopped and AA patrol told him that the fuel pump had burnt out. He replaced like for like. Ran for several thousand miles until recent problem. Still don't know of course if this was as per original build. Mike.
I think you have your answer then - as we've said, this engine ( DW10BTED4) and specifically from your VIN had a gauge without pump. That's why we ask for the VIN. So as said it looks like it has been replaced with a different unit with a pump and connected up.
Post Reply
