This morning I reset the BSI and carried out the procedure to the window 1 to 5 but unfortunately the fault is still there. Window goes right up then back down again half way!!
I think I will have to order a new regulator from ebay as it might be there is too much resistance with my repaired one even though I greased the cables and ensured to rubber runners on the door were lubricated.
Any futher ideas would be appreciated.
Brian
Citroen C5 MK3 1.6 THP 2012 Window Regulator Repair
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: Citroen C5 MK3 1.6 THP 2012 Window Regulator Repair
The reset will not damage anything. It is the official procedure to follow when disconnecting the battery or for reinitialising the vehicle ECUs.
IF the reset does not work,then I suspect it will be as you have said - the system is releasing the window as if the anti pinch mechanism is operational - and is therefore releasing the window down as intended. The Window ECU is detecting a strain / resistance on the motor when closing and releasing it again. So either they are not fitted correctly or it is the wrong type.
- My Cars: Citroen C5 1.6 THP 2012
Renault Laguna 1.8 petrol 2004 - x 4
Thanks Mark for all your help. I will oder a new regulator and let you know the outcome.
Brian
Brian
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
I have no idea how expensive they are on ebay/amazon etc but euro car parts are doing the complete replacement which is what i used for £65 with the discount this weekend, no hassle a simple swap over, comes with cables etc, though i did grease the cables.
Thanks I will look then up. In the past I have always used cable kits for about 10 pounds for other csts I owned. But in this case cheap is not always the best option. You live and learn.
Brian
Brian
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I would just add that ECP are horrendous for parts in my experience - one of which was a window regulator kit for a Picasso we ordered for family - arrived broken and in parts - twice Good Luck Brian!
Incidentally, you'll need the following part number as they changed these throughout the production period - this one is per your VIN:
9675898980
I believe these are Magneti Marelli ones:
http://vi.raptor.ebaydesc.com/ws/eBayIS ... 7000&ver=0
A lot of other choices here including Valeo and other brands for comparison:
https://www.bestpartstore.co.uk/9615561 ... -regulator
9675898980
- Donor 2023
GSF also do the same kit and have a discount this weekend also but is dearer but thinking back i got it from GSF and ask Mike T if it is still working
But yes i agree marc sometimes motor factor like the 2 mentioned are not the best
Thanks everyone for your help and advice. I priced a Citroen main dealer one comes in at £120 including VAT complete with electric motor (which I don't need).
I will look at all the alternatives you have suggested. Many thanks for providing part numbe,r Citroen dealer won't provide one only the price for the part .
Will let you know how I get one.
Brian
Brian
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Actually Brian the unit for yours is £412.46 original, but they do a cheaper version (that won't include the motor for £119.75), so I suspect it is just the regulator cables they have quoted for! I had mine done last year and it was £500 when my window wire snapped at the NCP car park exit barrier. They didn't bother with the regulator - they just put a complete new unit in including motor. It was under warranty though.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Brian - on another note - whilst checking the part numbers above, I note there is a current recall on your C5, so if you have not been in contact recently, I suggest you get in touch and have your VIN handy. Tell them you are aware that Citroen Service is asking you to get in touch. They will be able to confirm what the work is and of it has been done or not.
Any work carried out should be done free of charge - but I certainly would contact them as it could be a safety issue.
Thanks for the info when I was at the dealer they told me about the recall. Its going in on Wedneday for a new water pump. They would not tell me why. However online people are saying the original pump is plastic and the new one is metal. Poor show but at least It will not cost me anything.
I will double check the Citroen regulator for price.
Thanks again
Brian
Thanks again
Brian
