RT4 Screen problem
Moderator: GiveMeABreak
- My Cars: 2cv6, JIANE, ACADIANE, 2-pot VISA, GSA Break Special, C5II Break HDI175
Re: RT4 Screen problem
Marc, that is good tip!
The original numbers for the display is either HITACHI TX18D30VM2FAA, or HITACHI TX18D30VM2BAA.
Personally I do not know what the difference is,they look the same to me. The first number is from my 2007 C5, and the latter is presumably form a mark III C5.
You can find them on eBay, quite a difference in the prices.
Hope that helps,
Vladimir
Hope that helps,
Vladimir
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Hi Vladimir - where are you getting the Hitachi ones from? The OEM of these units is Siemens VDO.
Those Hitachi ones are touch screens that are not used in any of these Head Units (apart from later SMEG screens). I would stick to the ones we know were in use at the time as they have to work with the electronic architecture of the vehicle. The Screens also contain an ECU, so has to be compatible with the Head Unit and the BSI.
Hi Marc.
You are right, but I am talking about the display/matrix itself, not the whole unit. The numbers are from two Siemens displays that I have and have opened to investigate whats inside.
The hi-res display uses a Toshiba display, not Hitachi, just for an example. I did buy it brand new after my screen developed a spot.
Vladimir
Vladimir
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, that explains it - as the numbers I didn't recognise. So they are the internal markings inside the housing of the panel itself, which of course isn't what we use to source replacements as it's not what resellers and spare parts suppliers refer to.
But a good idea Vladimir, in the event that he can't source a compatible complete screen, it may be useful to know what the panel make and model is. At this stage of the game, I think it will be useful for JML to see which panel he has, so that sourcing an identical one may be the solution. Useful to know
Hi Marc,
Yes, that is the way to go. Brand new screen for a fraction of the price...
I love to disassemble things ever since I was a kid. You have to know exactly what is what...
I did get the DEVHR screen off eBay some months ago, and it was perfect, but then (maybe after disconnecting it too many times) it developed two spots which made me very sad. It was such a nice upgrade! So, for about 60 USD I did buy completely new and original display, when even the cheapest second-hand ones are twice that with all the risks attached.
Just for the sake of information, Toshiba, Hitachi and Sony displays are now called "Japan display" and the factory is in China...
Vladimir
Vladimir
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Oh no, not China again - I was hoping they might be made in Japan or Europe - but wishful thinking!
- Locked user account
- My Cars: A brilliant C8 2.2 HDi 173
- x 37
Hi Guys and thanks again.
Vladimir, I presume that if I were to be able to get one of those Hitachi display/matrix (what is the plural of matrix ? ), then I’d need someone pretty damn skilful, like yourself, to be able to fit it ?
And Marc, thanks for the advice re connecting. TBH, I hadn’t done that before so I guess I’ve been lucky not to totally screw up my screen ! I suppose it’s obvious but I hadn’t realised there was a direct connection between the RT4 unit and the screen. When I look at the back of the RT4 will it be obvious which is the ‘quadlock’ ?
And so now, do I just keep looking on EBay for a complete display unit with a manufacturing date as close to mine as possible ? I have seen some in the past similar to the link you sent, but they were all much earlier and, as I’m sure you know, they were fairly different (colour of display etc).
I found your mention from some time ago about repairers and one of them, Clarion, is quite close to me but they’ve just told me that they don’t deal directly with retail customers
Cheers
Julian
Cheers
Julian
Julian Leyton (RIP) 2023
- x 37
Me again ! Quick question.
Do you think it will be ok to drive my car whilst the display is removed from the vehicle or am I going to fry something ?
I took a chance and started the car and drove it a few yards and it seemed ok, although I did hear one small unusual beep, although I suspect that might have been from my separate Bluetooth receiver.
Cheers
Julian
Cheers
Julian
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1383
Matrices. But matrixes is acceptable.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Neo, Morpheus, and Trinity!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Paul-R
- Donor 2023
I took the red pill...
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
jml wrote: ↑25 Apr 2019, 16:52 Hi Guys and thanks again.
It will require some careful disassembly - in order to see the label you have to get the correct one. The one to watch is any ribbon cables as these can be very fragile.Vladimir, I presume that if I were to be able to get one of those Hitachi display/matrix (what is the plural of matrix ? ), then I’d need someone pretty damn skilful, like yourself, to be able to fit it ?
The Quadlock is the large connector block that holds several other connectors in one large unit:And Marc, thanks for the advice re connecting. TBH, I hadn’t done that before so I guess I’ve been lucky not to totally screw up my screen ! I suppose it’s obvious but I hadn’t realised there was a direct connection between the RT4 unit and the screen. When I look at the back of the RT4 will it be obvious which is the ‘quadlock’ ?
Strange, must be a change in policy. When I contacted them regarding my RT3 repair, they were quire prepared to take it in and relieve me of £300 - as it happens I sold my C5 shortly afterwards. Mind you it was at the time when they had only just become an authorised Magneti Marelli centre for the PSA units - so a policy change no doubt so that PSA get a cut of any repair I suspect!And so now, do I just keep looking on EBay for a complete display unit with a manufacturing date as close to mine as possible ? I have seen some in the past similar to the link you sent, but they were all much earlier and, as I’m sure you know, they were fairly different (colour of display etc).
Cheers
Julian
Anyway, whilst I was searching about - I came across these people in Surrey - the undertake repairs of these units - so it may be worth contacting them for a quote. Link below to Cartronics:
https://www.cartronics.co.uk/case-studi ... ir-service
- x 37
That’s great, thanks for all that advice Marc.
Now keep your fingers crossed for me that I can get something sorted !
Btw Do you think I can run the car with the display removed without causing problems ?
Cheers
Julian
Cheers
Julian
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
