Ok, good luck - don't forget the wellies and suitable attire Roger:
HELP-- LDS fluid all overthe place!
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: HELP-- LDS fluid all overthe place!
- white exec
What the LDS tank has to withstand (if you don't remove the cap) is essentially simple.
If you lift the car and let the wheels dangle, fluid is sucked out of the tank, to fill the suspension, with the restrictor valve in the cap allowing air in.
But, if you leave the cap on tight, and then quickly drop the car back on to its wheels - as a tyre-fitter might do - a large volume of fluid rushes rapidly back into the reservoir, and the valve cannot cope with this sudden rise in pressure - and the tank can split.
So the recommended procedure for putting the car back on to its wheels is to return the car to the ground with the cap off with the suspension still on highest, and only then refit the cap, and then reset the car to Normal height. This last will be a controlled and gradual lowering, which the tank and system should do without damage.
- My Cars: 2019 C5 Aircross 2litre diesel, auto.
2018 C4 Pic2 Spacetourer auto. Seems nice so far.
2019 C4 Cactus manual. Didn't like it, lots of niggling points. sold.
2011 C4 Picasso excl. - shaping up to be a disaster, bought June 2019. P/X'd
2009 Citroen C5 X7 exclusive, auto, LHD, 207500km (129000miles) now sold
Citroen Xsara Picasso excl. 2004 2.0 Hdi, RHD, 64000miles. (sold)
Citroen C3 Picasso excl. 2016. sold.
Two Xantias, one petrol, one diesel. sold.
In the past: Renault 16 (in about 1977, for a year). With front pass. seat out transported full bathroom suite from Cambridge to Derby!)
Renault 4TL (in 2011, for a year) - x 9
My situation is that the car is in LOW setting with all 4 wheels ON the ground, with the tank's cap OFF.
So - when I jack up to all 4 wheels off the gound, the level of fluid should just drop?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes understood Roger, so like I suggest, the system was probably well - pressurised and obviously the cap hadn't been opened for some time. Fingers crossed you’ll be ok from now on.
Had this been the typical situation that the procedure linked to is designed to prevent and as Chris mentions, I suspect you would of split the tank with that amount of pressure in the system. So critical for future tyre fitters to be made aware of the requirement - so get a few stickers printed off.
