Low Presure Pipe - How to replace
- Sloppysod
- My Cars: Citroens
1 x GS, 1 x GSX (Banger raced), 1 x GSA,
2 x CX Famililles, 1 x CX GTI,
BX, XM, Xantia, C5 Mk1,
C4 (Coupe), C4 (B7),
C5 (X7)
Renault
R4 Van
Fuego
Clio Campas - x 212
Re: Low Presure Pipe - How to replace
Cheers Marc, so does that mean that you should only add fluid to the reservoir when it is fully depressurised and not when at the low position?
Stu
Major interventions
C5 Steering rack @ 58,000 mi
4 discs & Pads @ 63,585 mi
2 (AM6) oil exchanges @ 58,876 & 72,378 mi
Major interventions
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
No it should be fine on lowest setting as you need to have the engine running when you bleed the system anyway which requires topping up.
Did you find the part number for the hose?
It's 5mm, and in my case I used a 6mm fuel hose. Depressurization was not needed, since it's a return line. Hose seemed fine in the rubber, but was cracked in 4 places - so it was not possible to cut 1cm in one end.
