i never have a problem bleeding any of the cit/pugs and i dont get all complicated by using tanks and bottels,keep it simple just take out the plug in the top n/s of rad with engine and rad/header tank cap off and heater on hot,top up coolant till it comes out of plug hole and stops sinking,replace plug remove the other two bleed valve capsput more coolant in,if nune comes out of bleed points,now start engine bring revs up a little bit untill coolant comes out of these points replace valve caps,continue to run engine with rad/header tank cap off for a few mins refit cap,now run engine till fans cut in then when they cut back out gently open cap with caustion,if coolant is calm you have not any problems,if it erupts you have either got H/G gone or C/H
regards malcolm
ZX: overheating: help still needed!
