I wouldn't bother doing that - The BSI only passes the information on to the engine ECU and the transponder coil and itself of course - but it won't be the BSI I suspect - the data is simply not getting to the BSI, so there is likely nothing to handshake with or pass on. If the BSI is not getting the data, it is not going to make any difference.
Why don't you do the test I suggested with your PP2000? That will tell you whether the key is being recognised or not or whether it is getting any data. If you have your own PP2000 that has to be your first step as it is no good replacing parts that may be perfectly ok.
The transponder coil is incorporated into the steering lock - but there are no specific removal instructions for replacing this. It probably requires the 2 halves of the steering wheel cowl to be removed and then there are some screws that may need to be tapped out when replacing the steering lock - but I can't say for sure how the transponder coil is located into the unit from the data I have.
2006 407 coupe programming issue ? FOB
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: 2006 407 coupe programming issue ? FOB
- My Cars: Peugeot 407 coupe 2006
Thanks Marc, i need to get pp2000 somehow, this going to take a few weeks, i would appreciate if you could look for my response, perhaps subscribe to this post ? once i have it so i can check with you if i am doing things the right way.
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 317
No problems there Stan, Marc is 'subscribed' to every post....thankfully.
Pete
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
And yet he still has time for other things in life!
Thank You so much, one can be very isolated when you have nothing to guide you.
