what happens if I do not replenish Eolys fluid?
- My Cars: '03 C5 2.2 Exclusive Estate.
In the past:
'07 C5 VTX+ 2.2. 170hp Estate auto
03 C5 2.0 Exclusive Estate.
95 XM 2.5D Exclusive
94 Xantia 1.9D Estate
92 XM 2.0i
90 XM 2.0
Various CXs (CX22, CX Pallas, CX GTi, CX Estate)
81 GSA Pallas
1974 DS23 Estate
1974 DS23 Pallas
1970 DS21 Pallas EFI - x 3
Re: what happens if I do not replenish Eolys fluid?
Hi Simon - thanks for that. However, mine is a 2007 2.2HDI 173hp using PATfluid (176). Any ideas on getting the system to reset itself? Would a BHI reset solve it or is that something completely different?
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
When you say that the garage has 'reset the code', do you mean they reset the fault code / message? You also need to tell the car that fluid has been replaced otherwise it will think the level is still low.
Pete
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
No a BHI reset wouldn't help. The early cars were a pain to reset the system , even on lexia (had to replace the ecu on mine in the end), but it should be a lot more straight forward on the later cars as the functionality was put into the main ECU. Are the garage following the reset process properly?
Simon
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
Yes, you may have come up against this.
- Donor 2023
The DW12BTED4 doesn't have a separate ECU ; it was one of the big updates (along with changing the inlet manifold from plastic to aluminium)
Simon
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
One should always use the guide that I put up above as the systems used are based on vehicle build date - not engine type.
But on some of the vehicles the ECU could be a bit of a sod to reset. Who is doing the reset for you and are they using a Lexia to do it?
In the past:
92 XM 2.0i
90 XM 2.0
81 GSA Pallas
1974 DS23 Estate
1974 DS23 Pallas
No, they don't have a Lexia unfortunately - rare as hen's teeth in this part of Shropshire. They have an Autel. Is that up to the job or is it limited with Citroen diagnostics?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I would really try and eliminate that as the issue by getting somebody to try the reset with a Lexia to be honest - that way you can rule it out.
Check out the member list:
viewtopic.php?f=19&t=56452
In the past:
92 XM 2.0i
90 XM 2.0
81 GSA Pallas
1974 DS23 Estate
1974 DS23 Pallas
Hi Marc,
just read your reply - many thanks as ever.
Actually, total success after all - another garage with a 'Snap On' diag box sorted it all in 5 minutes.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Excellent! Not all diagnostic tools are the same - evidently!
If you have trouble again, I have a Chinese Lexia and two C5s and based in Tenbury Wells. R
- My Cars: 2011 Citroen C5 X7 (2.0 HDI 163)
2011 Renault Laguna GT Line tourer (1.5 dci)
2002 Renault Laguna (1.8)
Hi all,
I have a 2011 C5, 2.0 hdi, I phoned Citroen and they advised me to use kit 9736 A1, I refilled the tank myself after buying the kit. This was Eolys Powerflex fluid.
However, I have a green connector on my tank which would suggest that this is now not the correct fluid.
Any assistance?
Many Thanks
Any assistance?
Many Thanks
Build date takes priority over the click fit connector.
Either your VIN or R.P. Number from the tyre label will confirm what fluid you need.
I reckon though being a 2011 model it should be eolys EXTEND.
Ok thanks for your reply.
My VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
I would very disappointed with Citroen if they had advised on the incorrect fluid. But having my doubts now.
Ex 2002 Renault Laguna 2002 (1.8)
Ex 2011 Renault Laguna GT line Tourer (1.5 dci)
2011 Citroën C5 X7 Tourer (2.0 HDi 163)
Your RP number is 12491 so as i suspected it should be Eolys EXTEND.
Part number 1623961580 for the 1 litre or part no 1623961680 for the 3 litre.
