Yes around 180rpm
Diagbox can't find ckp & frp ?
- (Donor 2017)
- My Cars: 09' Peugeot 207 1.4 Vti
- x 5
Re: Diagbox can't find ckp & frp ?
So does this tell me the crankshaft position sensor is good? Still can't find info for cam & crank sync, should there be any anywhere ? Sorry if these are draft questions.
thx
thx
'13 3008 1.6 HDi GripControl - x 1003
Yes, if it shows a cranking speed, then it knows it is going round, so the sensor is OK. There may not be a cam / crank snych point - I've not looked at any petrol engines, so can't say for sure. You maybe need some old school work first - does it smell of petrol when cranking it, suggesting that it is injecting fuel but no spark? Alternative if there's no smell of petrol, then is there a spark? Does it say in the engine ECU somewhere 'unlocked' suggesting it has detected, and approved, the key?
Unlocked status may be found in the BSI, actually, can't remember exactly!
- (Donor 2017)
- x 5
Yeah there is a smell of fuel when cranking + I can hear the pump priming with ignition on. Yes I saw that the ECU was 'unlocked' in one of the menus.
Yeah I'll need to check the basics next, I'll look at spark first. I just wish i had a code or two to send me in the right direction!
Anyway thanks for the help
