Many problems & don't know where to start
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
Re: Many problems & don't know where to start
You might want to try turning it over manually to check that the engine is not hydraulic locked by a cylinder full of fuel.
- My Cars: 2008 Laguna 1.5 DCi
- x 235
Changing the oil won't really solve any problems except the high oil level. You need to find out whats causing the problems so the car needs to be scanned. There are usually back street mechanics that will scan your car for cheap if you can't afford the dealer diagnostics. There are people on this site that have the dealer level diagnostic tool that would be happy to scan the car. They won't rob you maybe just a few beer tokens or tea and biscuits (chocolate digestives at a minimum)
Oh buggle
- Paul-R
- Donor 2023
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
We still don't know for sure if a DPF is fitted as the VIN hasn't yet been given. If @Namele55 could post that up we could move on properly.
- x 235
The faults are stored in the cars ECU starting it isn't necessary
Oh buggle
- My Cars: Peugeot 308 sw sr 1.6hdi
I'll pm the vin number after work this evening
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
You can safely post the VIN into the Forum. The software will automatically obscure it (although Moderators will still be able to read it).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Keep the oil, let it settle and see if it is ultra thin or water contaminated....also if you can change the filter before refilling.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Paul-R
- Donor 2023
In fact definitely DON'T PM the VIN as the forum software masks the number and staff can't read it there.
Ok so I changed the temp sensor which sorted out the fluctuating gauge, mechanic coming out at lunch time to replace the copper injector seals which he said was what the problem was. Will see what happens when he's done & let you know
Ok so the mechanic came out & replaced all the copper injector seals, the ones that came off were absolutely shot!
I took the car out for a small run after he'd done & it seems much more responsive, less smokey & generally much smoother.
So the temp sensor & injector seals seem to have been the problem. Must say I'm glad I didn't have to splash out for new injectors. I'll keep an eye on things & let you all know how it runs over the next few weeks, thank you all for the responses
- white exec
Good news on getting those two things identified and fixed!
