C5 X7 rear suspension fun.
x 4923
Re: C5 X7 rear suspension fun.
Post by GiveMeABreak »
No worries, but Chops, mash, peas and gravy with a glass of OJ for me tonight.
Manuel
Post by Manuel »
Tengo un problema igual con el citoen c5 x7, y no se como poner las mediciones en el escáner, si alguien me puede ayudar estaría muy agradecido :cry:
"I have the same problem with the Citroen c5 x7, and I don't know how to put the measurements in the scanner, if someone could help me I would be very grateful"
Reason: Translated text
x 4923
Utilice inglés para publicar en este foro. Puede usar Google Translate si el inglés no es su idioma nativo.
You need to undertake the measurements then the calculations and ultimately enter the values into the suspension ECU with Diagbox or Lexia.
