On your Bike
old'uns
x 127
Re: On your Bike
Unread post by old'uns »
RichardW wrote: 27 Feb 2021, 20:39 That was a decent ride Jim, I only managed half that!
and i managed half of yours today :)
absolute mayhem over the Chase today....groups walking full width of paths, dogs not on leads, dogs on long retracting leads, call 'bike coming through on left/right'...muppets stepped to the side called, MTB'ers not doing themselves any favours..at least 4 groups i saw were definitely from same household, well not that i know many households with 6+ who all ride MTB's :-D
x 1329
Re: On your Bike
No 1 son has moved up to a nearly full size MTB now, so considering building a bike shed as they occupy a lot of the garage To save ground space wondering about standing them up. But how much room do we need....
Only one way to find out :lol:
x 7427
Re: On your Bike
Skull wrote: 28 Feb 2021, 18:44 My fastest Huffy ride so far 8-[ 24.5 miles 1,239 ft 1h 52m :!:
Great riding Skull :D
Skull wrote: 28 Feb 2021, 18:44 Not sure how this Strava thing works but 252 miles for February is more than I would have done on my Cross-trainer (RIP)
If you're anything like me then real miles out on a real bike out in the open air are far more pleasurable then any rides indoors, even with Zwift, so you do many more...
Time and mikes just fly by when I'm out on a real ride but drag terribly on the Turbo Trainer...
Skull
x 266
Re: On your Bike
Unread post by Skull »
CitroJim wrote: 01 Mar 2021, 05:29
If you're anything like me ....
I'm not :oops: according to Strava anyway :lol: but I get your point :wink:
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
x 7084
Re: On your Bike
Australian observational humour, yes it has its merits...enjoyed these
Regards
Timmo
(Donor 2022)
x 168
Re: On your Bike
Unread post by Timmo »
RichardW wrote: 28 Feb 2021, 23:11 No 1 son has moved up to a nearly full size MTB now, so considering building a bike shed as they occupy a lot of the garage To save ground space wondering about standing them up. But how much room do we need....
Richard, if you one up, one down them you can fit a good number ina very short space, space the hooks out at 1ft intervals, i currently use these for hanging duties, easily fit a 3" tyre on a 50mm rim https://www.screwfix.com/p/smith-locke- ... 58mm/1998j
will grab a picture of the bikes hanging up in the shed at the mo in a little while,
'58 C2 Code
'58 partner teepee outdoor
Timmo
(Donor 2022)
x 168
Re: On your Bike
Bike hangers
Bike hangers
Couple quick shots of the hooks/bike hanging, the old shed I had the corner area filled, almost half the shed length and half the width, had 13 various shapes and sizes hung up one up, one down, the rarely used ones I used to turn the bars 90 degrees,
'58 C2 Code
x 7427
Re: On your Bike
I keep my bikes in the house :) One even lives in the lounge....
x 5312
Re: On your Bike
My grandson has four - and sometimes more - in my daughter's dining room. No room for anything else in there.
Skull
x 266
Re: On your Bike
Well what do you think to my new budget bike :?:
Torrane 17" frame 26" wheel £211.65 with Discount Code WINTER15
TORRANE.CO.UK
TORRANE.CO.UK
Mountain bike for Adults Men Women Kids with height between 5.2 to 6 ft.
High quality aluminium 6061 frame makes this bicycle light weight and easy to ride. [Approx 14.3 KG net weight on Ebay listing]
Free Accessories: mudguard, bottle holder and stand included, saving you extra £30 (limited time offer only)
Specifications:
Frame: Light weight strong and durable Aluminium Alloy 6061 T6 17" frame
Forks: 100 mm sanctions, high carbon steel with suspension fork
Gears: 21 speed Shimano TZ500 gear set for easier hill climbs
Breaks: Mechanical Disk Breaks for smooth, controlled stopping
Wheels: 26” double walled rims for extra durability
Saddle: Memory Foam Saddle for ultimate comfort on your ride
Colour: Matte midnight blue paint
Delivery:
Free delivery - London zone 1 to 6 takes 1 to 2 days; for the rest of UK 2 to 3 days (estimated)
What’s included:
Bicycle as displayed in picture PLUS free accessories (water bottle not included)
Product manual
Assembly:
This bike comes 85% assembled, only front tyre, handle bar, seat post and pedals need to be assembled.
The cheapest bike in my Wheelbase shop is £415 which is out of stock, cheapest in stock is £500 so I thought I'd give these new guys a try ....
I'm not expecting a massive amount but an improvement over the old Huffy (17 Kg) which is approximately 25 years old, if it turns out the frame is a bit small I could pass this on to my daughter .......
Gone
Timmo
(Donor 2022)
x 168
Re: On your Bike
Set up on the new bike will be the biggest part in how it rolls along, firstly pop the wheels out and check the axles, these, are often over tightened at the build stage and feel stiff, brakes being cable disc are rarely set up properly either, the 'static' pad on the inside of the caliper should be wound out to the disc as close as it can, a passing glance on the pad is fine, you can see if it's too much by if it visably slows the wheel spin, then set your cable side up, wind ut the adjuster on the bars a few turns. Pinch the caliper arm to stop the wheel as such and reset the cable there, undo the adjuster on the bars and the brake should be sharper feel,
Check the derailuer hanger is straight visually from behind, very frequently bent in transit, headset will more than likely be lacking in grease! - hubs too, I would normally prestretch the cables when setting up to prevent the 2-3 weeks use Its not working properly call! 😉😉
I do apologise if this is simply telling you what you already know, but thought it may be helpful!
'58 C2 Code
Timmo
(Donor 2022)
x 168
Re: On your Bike
CitroJim wrote: 03 Mar 2021, 18:15 I keep my bikes in the house :) One even lives in the lounge....
I did have 2 of mine in the dining room when inbetween sheds in the summer, however, with a small dining room and Wide bars (760 + 780mm),it was somewhat of a hazard! :lol: :lol: :lol:
'58 C2 Code
Skull
x 266
Re: On your Bike
Timmo wrote: 05 Mar 2021, 10:32 I do apologise if this is simply telling you what you already know, but thought it may be helpful!
Not at all Timmo Many Thanks ....it's 25 years since I took one out of a box :wink: Disc brakes are new to me on a push bike even if they are cable operated ....
Gone
Timmo
(Donor 2022)
x 168
Re: On your Bike
The pads will require bedding in! General rule of thumb if 4 or t repeated hard stops from speed, I generally use one of the steep hills out the village as gravity saves my efforts!😁
'58 C2 Code
x 2849
Re: On your Bike
Nice to see them in the shed instead of hogging the road on our country lanes. :-D
