Navidrive RT4 8.31 update, no sound, Mirascripts
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Moderator: GiveMeABreak
tomno1
Re: Navidrive RT4 8.31 update, no sound, Mirascripts
Post by tomno1 »
GiveMeABreak wrote: 29 May 2023, 20:20 What is it you want to know? You've basically just put a load of settings there.
Are you asking if they are correct for your RT4?
Hello,
I would like to know what parameters belong to my vin number?
Hi-Fi Amplifier parameter?
And what should the other parameters be set to?
Sorry for my English, it's not very good, I'm asking about Hungary.
x 5709
Post by GiveMeABreak »
So if I understand you correctly, you have made changes to the BSI and cannot remember what the settings should be? This will take some time, so I'll see if I have time later to do this.
x 5709
I'm working on this now for you - should be complete in 20 minutes or so.
x 5709
Here you are - it took a while as I had to go through lots of long documents to check against your vehicle.
All the items I have marked in Red need changing to the values I have specified.
Parking Assistance* Present Rear
CD PlayerAbsent
Separate Control KeypadAbsent
Air ConditioningNo Air Conditioning
Under-Inflation DetectionAbsent
Voice RecognitionActivated
Steering Wheel With Fixed Central ControlsPresent
Overspeed WarningDeactivated
Auxiliary Audio InputActivated
Hi-Fi Amplifier*Absent
Geographical Area Of UseEurope
Linking Of The Volume To The Vehicle SpeedActivated
Fader FunctionActivated
AM WavebandActivated
Number Of Radio Aerials2
Locking Of Menu ButtonDeactivated
Wire Airbag ConnectionWith Wire Connection
Display Options
Parameter to be configuredValues to be configured
Retractable displayAbsent
Display of the external temperatureActivated
Auxiliary video inputActivated
Configuration of the Personalisation Menu
Display of the "driver’s seat clearance" optionDeactivated
Display of the option "partial opening of windows"Deactivated
Displaying of the "Visual overtaking assistance"Deactivated
Displaying of the "Audible overtaking assistance"Deactivated
Display of the "triggering of the rear wiping when reversing"*Activated
Display of the "ambient lighting"*Activated
Display of the option "daytime-running lamps"Deactivated
Display of the "automatic headlamp illumination"Deactivated
Display of the "assistance lighting"Deactivated
Display of the "adaptive lighting"Deactivated
Display of the "Automatic secondary brake"*Activated
Displaying of the "Selectivity of the doors (driver’s door or all doors)"Deactivated
Display of the "permanent boot locking"Deactivated
Display of the option "visual detection of an obstacle in proximity"*Activated
Display of the option "audible detection of an obstacle in proximity"*Activated
Configuration of the Jukebox
Jukebox functionActivated
Copy of MP3 CDAuthorised
Copy of audio CDAuthorised
tomno1
Post by tomno1 »
Thank you very much for your help!
This is a big help for me!
Have a nice day!
alexburnt
Post by alexburnt »
Hello everybody,
I have a similar issue than melj from the first post on my 407.
After letting it sleep without battery for 2 years, I got the same message on my RT4: “Please insert upgrade cd” when I restarted it and no sounds anymore.
It wokred perfectly before this "sleeping time".
My RT4 had already the Last update available (8.31)
I tried to play with mirascript to fix it but without success.
I tried the diagbox but did not have error on any the speakers.
My vin number is: VF3**************[VIN obfuscated, can be read by forum staff]
I don't know what elseto try. Could you please help me?
Many Thanks
Alex
x 5709
It's likely that the backup batteries for the unit have discharged, so have lost memory over 2 years.
There is a backup battery inside the unit. I suggest you put any changes you may of made using Mirascripts or Diagbox back to their original settings before you do anything else. Then the unit may need either a new memory battery or will need to be charged up from the vehicle when you are using it for a few days to allow enough time to charge it.
alexburnt
Post by alexburnt »
Thank you for your reply,
Is the "unit" the RT4?
I'll check the battery.
I forgot to say that we use this car daily since 6 month now and that beside the "no sound' issue, the RT4 is behaving normaly.
x 5709
Well since you posted in this thread, I have assumed it is, but if you are not sure, provide t he VIN and I'll check. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
alexburnt
Post by alexburnt »
Sorry my english is not perfect, I meant to ask if what you called the "unit" was indeed the RT4 module (just to be sure where to search for the battery).
Should I completely remove the RT4 unit form the car and dismantle it in order to find the battery?
I posted my vin number in my first message.
I also forgot to add that I canceled every modification or test that I did with either mirascript or diagbox since none of them was succesfull.
x 5709
1) Ok so yes, you do have the RT4.
2) The backup battery is located next to the fan on the RT4 it will have a black case - that should be the battery and spares can be ordered from Peugeot or Citroen as it's the same part.
3) Be warned that replacing the battery may not resolve the problems. It will cure the loss of the permanent live battery feed, but it won't fix what has already happened, as you seem to have lost your User.com data that has the configuration for the vehicle including equipment like parking assistance and menu settings.
4) The only way I know how to restore this is from the dealer who will need to set up the GPS settings and telecode the unit for you as if it was a new factory fitted unit, or locate somebody with the exact same car model and the same trim level and equipment and RT4 system, and ask them for a copy of their User.Com date that they could provide you using a Mirascript commend to backup their data and send it to you. As long as you still have the display screen working so you can see the questions and answers, you could then use Mirascripts to restore the file from USB back to your hard drive in the RT4.
That may then restore the settings.
