Not on MK 1s as wheeler says - there is no speed regulation on the Cruise control stalk. The overspeed warning is available independently (I had this on my MK I but no cruise). It is as James says a matter of reaching a desired speed, holding the end of the stalk in and then getting the 'gong' sound. Then you get a warning when you exceed that speed - but it is not a speed limiter device, just a warning.Paul-R wrote: ↑30 Jan 2019, 09:42 No, on the Mk1 there is a separate stalk for the cruise control and, IIRC, a wheel which can be set for CC or overspeed (thanks for the correct name) operation. The X7, I'm fairly sure, has a separate button on the steering wheel boss to flip between CC and overspeed but I have never operated it.
MK I C5 cruise stalks have the cruise only barrel setting, not the limiter option at the bottom. It was included on the MK II on.
See the pictures in Wheeler's guide, which is a link referred to in the link above.
