Hands free kit for C5 X7
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
Moderator: GiveMeABreak
x 3109
Re: Hands free kit for C5 X7
Post by GiveMeABreak »
I’m not sure what you are referring to CC CB?
Also, did you use the battery disconnect procedure before removing it? You should always follow the procedure as these systems are live with the engine off and removing equipment with the battery on can cause problems.
Follow this guide before disconnecting any kit and again later for reconnecting the battery:
viewtopic.php?f=51&t=61997
BounceDK
Post by BounceDK »
:rofl2:
I’m refering to the connection terminal at the back of the RT16.
See above. Right now I’m using the First metode.
x 3109
Ok, I'm with you now! The only issue I can see is that others here have not had much success in getting the pre-existing wiring from the flat cable factory fitted microphone to work. I think this is probably down to it being routed through an interconnected harness. Most here have actually bought a separate microphone cable and wired it in directly to the back of the head unit.
BounceDK
Post by BounceDK »
Great idéa. Can you tell me a favorite and Can I get one with pinouts?
x 3109
Item 5, Part 659365 priced at: £28.63 inc UK VAT - or the equivalent in Denmark. The pin outs are in the previous wiring diagram that I put up on the previous page:
viewtopic.php?f=52&t=61730&start=15#p610868
If you already have the microphone that is the same part as in the picture below, then no point ordering it. You'll just have to be a bit creative and wire it is directly.
BounceDK
Post by BounceDK »
Ok. I think I will make a new cable for the original mic in the roof lamp.
Can I use normal cable or do I have to make a balanced one. Do the mike use phantom power like the mike we use for rockbands audio... ?
I nearly give up, but I do not. I believe I will have succes that way.
Once more.
THANK YOU very much. Your help here is outstanding =D>
x 3109
As much as I like a bit of :rock: I don't think they use Phantom power in these microphones because the power can damage ribbon connectors which are very sensitive. The microphone is connected to a ribbon cable, so I would just use normal wire to connect the mic to the head unit. :-D
BounceDK
Post by BounceDK »
Great. That is much easier...👍🏻👍🏻👍🏻
BounceDK
Post by BounceDK »
Hey guys.
Now everything Works perfect.
Thanks a lot for your help.
If you come around my place I give a beer or two.
Have a great summer.
x 3109
Well done, glad it’s all sorted. :-D
