Find the answer in the FCF..
- x 1508
Re: Find the answer in the FCF..
- x 1508
Just found out that the Hungry Horse Chain have a pub called the "LoDekka" bit of a link back to the Bristol Lodekka which made its way to be a cafe at the Chainbridge Honey Farm
Bit more delving and the Bristol Bus Building heritage started off in Brislington!
Brislington old tram depot
Geof Sheppard / CC BY-SA (https://creativecommons.org/licenses/by-sa/4.0)
- Donor 2020
- x 991
One of my lady customers had a butcher's business around Bristol, she had one of her shops in Brislington
- Donor 2019
- x 1637
This may get a few cogs turning. What was the problem with this:
- x 1508
All the sevens on the likes Mick!
Looks like I may have to delve into a dark area of the forum I have never ventured into before......I just about understood coathangers for aerials...
- Donor 2019
- x 1637
Excuse a little celebration of the triple seven:
- x 1508
Well I found the post Mickmickthemaverick wrote: ↑02 Jun 2020, 21:35This may get a few cogs turning. What was the problem with this:
- Spoiler: show
- Donor 2019
- x 1637
The secondary story here is that a few weeks ago, before lockdown, I noticed a deterioration in the AM radio signal. I found another 3 tail aerial on ebay and ordered it. I also found and bought a new head unit because the screen had begun to flicker and when both arrived I put them in the boot and the performance improved overnight. I think I posted that up at the time! Anyhow two weeks ago the AM began to deteriorate again so last week I decided to replace the antenna. When I pulled down the roof lining I discovered that the 3 tail aerial I had bought only had 1 plug the same as the car. I immediately came indoors and searched for the correct replacement. Luckily I found an original 4 tail aerial and ordered it immediately. I then went back to the car and reconnected the existing aerial while I await the replacement. Guess what.......it has been perfect since then so when the replacement 4 tail arrives I will have the dilemma of do I leave it alone as it is working or do I swap it out for the correct part which I should have fitted a year ago?
- x 1508
ReFind the answer in the FCF..Q9
bobins wrote: ↑03 Jun 2020, 17:52If it wasn't the Rapier, then it was probably the Minx.
You can see whay they called it the Alpine as it shares so many similarities with its namesake the Sunbeam Alpine - they both had 4 wheels, they both had some doors....ummmmm there must be more similarities than that ?![]()
Regards NeilFind the answer on the FCF Q8
Bobins Mentioned the "Sunbeam Alpine" today in our whatsthisthen? In different incarnations in 2 iconic Movies it has been mentioned on the FCF.....What are the two Movies![]()
- Donor 2019
- x 1637
TOH
- Spoiler: show
- x 1508
Have a little paddle Mick not difficult to find although I did expect you to come up with your number 2 which is right. I think I did a post ages ago about a bit of misidentification of that one. As for your number 1 the film and the car and the location were a touch more glamourous. However saying that check with IMCDB and I wouldnt be surprised if you found a version of the alpine in your number1.
regards Neil
and it does in a major way as it turns out. So both correct.
See if you can find the glamourous one though!
- Donor 2019
- x 1637
My number one definitely had one in it. The girl that rescued Jack from his London Buddies did so in the alpine and then she was locked in the boot when it was shunted into the river!! However I have reason to believe you are looking for
- Spoiler: show
- Spoiler: show
- x 1508
I re-edited my post Mick as The Alpine in Get Carter was a three star rated ca r[*][*][*] Vehicle used by a character or in a car chase!mickthemaverick wrote: ↑03 Jun 2020, 20:05My number one was definitely in it. The girl that rescued Jack from his London Buddies did so in the alpine and then she was locked in the boot when it was shunted into the river!!
so right answer for 1 and 2, but heres the glamour one....Grace Kelly and Cary Grant as you have just posted while i was typing!
REgards NeilNewcastleFalcon wrote: ↑27 Feb 2016, 11:21A previous incarnation of the Sunbeam Alpine with Grace Kelly and Cary Grant
- x 1508
..and the BBC made a little Faux-pas when introducing an item on Aston Martin building a new model in South Wales, against a background of JB driving a Sunbeam Alpine in Dr No.
NewcastleFalcon wrote: ↑27 Feb 2016, 10:36From the BBC Report........"Its Bond's Favorite motoring brand and now a new model is to be built in South Wales"......so which model is it?......(picture below...not the new model)....no further clues....(just yet)
- x 1508
Regards NeilFind the answer on the FCF Q9
What is the name of the Pub described by an FCF Member as the highest and most remote pub in Southern Englandand where had they walked to earlier that day.
