Engine Oil for an older engine
van ordinaire
(Donor 2017)
Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects!
x 405
Re: Engine Oil for an older engine
Post by van ordinaire »
Hell Razor5543 wrote: 02 Jan 2019, 23:03 Asda do their own oil in 5l cans as well (I know, I have two of them in the boot of my car), and every so often they do them with quite a discount (£14 instead of £21, IIRC). They also have a car checker SMS system, in that if you enter the reg and send it to the text number it will reply with the (Asda) oil that is most suitable.
I wonder if only certain branches carry the 5ls, that would explain why I've not seen any recently - perhaps only the larger ones?
Update:
& so it proved to be - had a look in a larger branch &, yup, a choice of oil in 5l's, although only one at what I'd consider a sensible price: 10/40 for £16!
Tried that text thing &, as I expected - no response! Why, 'cos the Xantia's number doesn't seem to be on whatever database companies use.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'99 Cadillac STS :|
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3007
Post by Hell Razor5543 »
I have noticed that Castrol supply oil in 1L and 4L quantities. I have also noticed that (certainly vehicles I have had usage of) car seem to require around 4.3L oil. The cynic in me thinks that the oil companies are (as usual with large corporations) taking advantage of their captive clientele.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
4L is just a ploy to get the shelf price down.
How many owners actually change their own oil nowadays?
I usually buy Repsol 20W/50 diesel spec mineral in a 4x5L carton, at about €20 a tub. Gets used on both cars, every 6000mi/10,000km. Recently started buying it online from Mister Auto, where there are non-stop discounts.
kenbw2
(Donor 2017)
My Cars: -
Current:
2000 Citroen Dispatch 1.9TD: daily driver
1997 Peugeot 806 1.9TD: backup vehicle
1996 Citroen Synergie 1.9TD: donor car
1997 Citroen Xantia 2.0 16v: Aussie play thing
Former:
1999 Citroen Dispatch 1.9D DW8: got a new owner
1994 Peugeot 106 1.5D: killed by a deer
1996 Peugeot 106 1.5D: cremated
x 23
Post by kenbw2 »
I'm using a thicker 15W40 mineral oil in my 1.9D DW8 to try to lessen the crank shaft oil seal leak I have. It seems to be alright, and leaks a little less. Don't have to worry about replacing it every few thousand miles as I go through a full oil change every 6 months or so :? .
I'm considering biting the bullet and just getting the seal replaced.
van ordinaire
(Donor 2017)
My Cars: Citroens:-
others:-
x 405
white exec wrote: 03 Jan 2019, 21:41 4L is just a ploy to get the shelf price down.
I thought the idea was to design 1 4l container that wasn't obviously smaller than the 5l - & sell it at the same price!
Interestingly though, I see Repsol oils are available in 4 AND 5l's.
Not sure about 20/50 in "our" engines though - outside the tropics/N. Africa.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
van ordinaire
(Donor 2017)
My Cars: Citroens:-
others:-
x 405
Mineral oil doesn't creep like synthetic, which is probably more important than viscosity, although the C15 lives on 15/40 as a matter of course - & the only reason the Xantia got 10/40 at the w/e was (a) it was all that was available (AND turned out to be cheaper) at the time (b) it IS January!
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
jsp
My Cars: AX 3x 10E 1.4 GTI 5drs 1.0i
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
1994 AX 1.4 5dr TGS GTI
1994 AX 1.0 3dr Escapade
1996 AX 1.1 3dr spot Burgundy
1996 AX 1.1 5dr Verte
2003 peugeot 206 xs leather with auto A/C
x 12
Post by jsp »
I use personally 5w50 which is a HC synthetic oil something between both semi and full syn.
on the race TU engines I use 10w60 with zinc if no catalyst is possible.
van ordinaire
(Donor 2017)
My Cars: Citroens:-
others:-
x 405
Found that although, generally, oil's more expensive sur le continent - often €40 - 50+ for 5ls - Norauto actually have some budget 15/40 for €9.95, I suspect it's re-refined, bit like that that el cheapo 20/50 we can see on the shelves, particularly in supermarkets, D-i-Y sheds & the like.
Anyway, definitely in the "if it seems to good to be true . . . " category. Got a result in Auchan though, 5l of their own 15/40 "diesel" oil was €13.50; bought 2, so all set, probably for the rest of the year's oil changes for C15 AND Xantia (assuming the latter doesn't use any, as too early to tell).
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1205
Post by Peter.N. »
https://www.ebay.co.uk/itm/MANNOL-Defen ... 2749.l2649
You won't find much cheaper than this although its gone up since I last ordered that was only thirty three pounds.
van ordinaire
(Donor 2017)
My Cars: Citroens:-
others:-
x 405
That IS an extraordinary price, especially as it includes p&p - which can't be cheap for 20ls of oil. Means it's hardly worth me getting a "drum" from Mole Valley Farmers (my local source of oil in bulk) - not that I can remember if I ever actually checked the specs. of tractor oil, to see if it's suitable.
Must admit I'd never heard of Mannol - 'til this evening when I was looking at the price of LHM, as I'd forgotten to get some in France (just as well, it's twice the price GSF are knocking out the Total product for.
Curiously, that €9.95 15/40 from Norauto is €14.99 in Auto 5 (which seems to be their Belgian operation)
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
My Cars: Currently:
x 1205
Post by Peter.N. »
They do a whole range of oils. worth looking up. This is pretty well the same oil as I used to get from Trago's some years ago but its even cheaper than that.
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5721
Post by GiveMeABreak »
I've split the last few posts into a new thread to avoid confusion, as it veered off onto transmission oil.
viewtopic.php?p=598067#p598067
Please keep this topic related to Engine oil.
jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
x 12
Post by jsp »
Peter.N. wrote: 13 Jan 2019, 22:33 https://www.ebay.co.uk/itm/MANNOL-Defen ... 2749.l2649
I use drums as I run 6 cars 2 for main use 4 for hobby. It all uses 5w40 and 10w60 with or without zddp depending on catalyst or non catalyst. As for the diesel engines I run 5w40 HX7.
I have one 407 hdi runs on 5w30 dpf oil without a problem even with 250k mls +
My Cars: Citroen C5 Tourer 2.2 HDi Exclusive 173 6speed (daily family practical wagon),
Peugeot 406 Coupe SE 2.0 137 5speed (& originally auto), (former daily off the road for some TLC)
Peugeot 206 GTi-HDi 1.6 110 5speed (my wife's daily)
Peugeot 306 HDi Dturbo 2.0 90 5speed (long term project to reinstate inner wings, former daily. Too sentimental to let it go!)
x 1333
Post by MattBLancs »
I've had a drum of the Mannol stuff in 5w30 variant:
(from eBay &quot;my purchases&quot; )
(from eBay "my purchases" )
It's shot up in price since I got it as if I click through to the current listing it says £63.99!
There's some of it in the 206 DV6 at present - I know it's not a low SAPS version but was mid oil change on Sunday afternoon when I realised all the 5l bottles I had in stock (accumulated Eurocarparts own brand fully synthetic when on good offer) were 5w40 stuff to suit the Coupe instead :oops:
Picked up some 5w30, C2 spec from GSF on Monday, £30.99 for 5 litres, so intend a short change on the current "wrong" stuff maybe next weekend or the one after then back to the C2 stuff for a normal duration.
citroenguy
(Donor 2021)
Lexia Available: Yes
My Cars: Hobby car + daily: 1996 Xantia 1.9TD SX 84k miles
Past:
Citroën C5 I 2.0i 16V SX Saloon-04
Citroën BX16RS -88 stolen and burned :(
Citroën BX 19GTi -89
Citroën C5 II 2.0i 16v -05
Citroën ZX 1.8i 16V Break -96
2x Rover 620 Sterling
Rover 620Ti
Volvo 850
Various C5 and Xantia bought and sold
x 55
Post by citroenguy »
In my Xantia XUD9BTE i run 5W-40 in the winter and 10W-40 in the summer. Both recommended by Total
10w-40m is a bit too thick for winter use, as it can get to -30*C (mostly around 0*- -15*C)
But it makes for a quieter engine in the summer.
I ran my mk1 C5 on 0W-40 in the winter (OK according to handbook), it did consume a tad bit of oil on a long trip in warm april..
Oils are generally a bit of an "religion", i stick to what oilguides and manufacturer recommends
Engine oil seem to be very cheap in the UK.. If i order a good brand oil (5L) from germany/poland its like 35£ + shipping
A modern oil in the autoparts store can be over 100£/5L, many main/OE dealers can charge around 30£ a litre!!
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Post Reply
