Citroen C2 locking issue
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: Citroen C2 locking issue
Don't forget you'll need to do ALL the keys you intend to use in the same session - or it will lock out any others!
- My Cars: C2 gone, DS3 gone now on a DS5
Thanks Marc, will order two more from my supplier first so all my blades with be functioning!
Would you be kind enough to supply the part numbers for the whole cigar lighter assembly and the drivers window switch? Once I manage to get the RD4 to sit in it's place that'll be me finished!
Had a bit of a scuff last week that buggered up the drivers door opening, got that done today as well
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries here you go:
However, this lot are selling the cigar lighter and housing complete here for £12.45 delivered:
https://www.ebay.co.uk/itm/GENUINE-PEUG ... ctupt=true
Cigar lighter only: 822754 | 6554L7 Driver side window switch |
Thanks Marc, do you have the whole 12v socket code? Mine is knackered!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
15?
Thanks Marc, you're a Saint!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
15 should be included in both parts in that last link Tom, the eBay seller is showing the lighter and the holder and light fitting.
Thanks Marc, someone was breaking one near me so I have the whole console! How to I get the connectors off for the windows? They seem seriously stubborn!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The window switches should be able to be removed with a trim removal tool. A flat blunt instrument should allow you so push in the plastic clips that hold it in - whether these are at the sides of the switch or at the front or back or both I can't say Tom - there are no details on it - but if you have the replacement switch to hand, I assume you'll be able to determine what parts you have to lever on to release it.
Bit fiddly but all done!
If I replace the passenger side with an automatic button would this work or are the windows equipped differently do you know Marc?
Just need to find somewhere tidy to hide my AUX lead and I think that'll be me finished at last!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Well done.
If you're referring to the sequential one-touch button then no, as these actually have a different motor for the sequential and standard type of window lift, and I suspect they are controlled differently too.
The central locking on my C2 recently stopped working ... after several hours of trying different things I have two suggestions that could be worth a try if you have a similar problem:
1. Change battery in key fob - and make sure you put the new battery in the right way round
2. There is a manual locking mechanism in the door frame on the passenger side (it's a little black slot for the manual part of the key) - I turned this to the left and it locked that door - when I retried the central locking it now worked! Yey!
