Citroen C2 locking issue
- My Cars: C2 gone, DS3 gone now on a DS5
Re: Citroen C2 locking issue
Just need to go out and have this cut, and the. Will try again.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
So that will just be for the starting then - no remote locking - but should be suitable to test the coding if it.
Yes, just want to test my aerials etc, if this works i'll (begrudgingly) order an expensive two button key!
Can mine be programmed to have the 3 button key at all?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No, that one would't serve any purpose as the middle button functions have to be a feature supported on the car itself - plus it would likely be a different board anyway. Let us know how you get on.
Back on the road!
Can’t lock the bloody thing though!
£5 pug transponder aerial was worth every penny!
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4889
A bit of progress at least.
Too right! AUX cable works now as well. Now to bury my head in the manual and work out how to set the clock and turn off TRAFFIC FLASH.
Was on the A444 earlier listening to Sledgehammer by Peter Gabriel and I was interrupted by the traffic alert!
Marc- would you add me to the list of people with Lexia and willing to help please?
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1369
Not even using the old key-in-the-lock method?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Excellent, well done for following it through.tomjyoutwit wrote: ↑08 Jan 2019, 17:39
I'll ask Steve to add you to the list, but could you perhaps update your profile to narrow down your location as the West Midlands covers a large area
Key in lock method locks the drivers door- that’s it!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That’s normal, the same happens with the C3.
The cable holding the transponder aerial has worked itself loose over night. I’ve put it back in but can’t start the car.
Does it have to go in a precise way or is it symmetrical? I’ve tried both sides but no joy.
Do I need to clear the fault codes first?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Is this the replacement you bought that fits over the ignition barrel?
Yes, the cable end has worked itself lose as it does not have the same fitting as the Citroen one.
Kettle's boiling and i'm going to go outside and run the key programming through Leixa so I can get an indication of when the coil is working, as opposed to fiddling and trying to turn my engine over over and over again!
