Reversing lights upgrade?
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
Re: Reversing lights upgrade?
OK, just don't expect pretty pictures of relays - or even a wiring diagram BUT I will need a little time to think this through & set it out in any meaningful way.
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Just bear in mind the CAN wiring on these vehicles and any hashing or splicing may have unintended consequences....
- Donor 2023
- My Cars: Peugeot 504 2.0 diesel 1984 (built in South Africa)
Peugeot 505 GTI 1986 (built in South Africa, and brought to Britain 1988)
Citroen XM V6 (UK)
Citroen Xantia 2.0 HDi 1999 (excellent car but it ate suspension spheres)
Citroen C5 2.2 HDi Exclusive Auto 2001
Citroen Grand Picasso II 150 HDi EAT6 Exclusive 2015 January - engine rattled until replaced. Gave it back at 1600 miles.
Citroen Grand Picasso II 150 HDi EAT6 Exclusive 2015 July - still going strong - x 4
GiveMeABreak wrote: ↑07 Feb 2019, 21:41 Just bear in mind the CAN wiring on these vehicles and any hashing or splicing may have unintended consequences....
Absolutely. Thanks
2015 (Jul) C4 Grand Picasso 2.0 Bluehdi 150 EAT6 Exclusive+ now running on 17" wheels - SO MUCH MORE COMFORTABLE AND SMOOTH THAN 18" - AND better fuel economy
- Donor 2023
Citroen XM V6 (UK)
van ordinaire wrote: ↑07 Feb 2019, 21:34 OK, just don't expect pretty pictures of relays - or even a wiring diagram BUT I will need a little time to think this through & set it out in any meaningful way.
No problem. The reverse lights have been rubbish for 3 years already. Another 6 to 12 months won't hurt.
- My Cars: had:
2 citroen ds super 5
1 citroen ds pallas
1 citroen bx
1 citroen cx pallas
1 citroen dyan
1 citroen ami
1 citroen 2cv
2009 c5 x7 in Black 84k
2011 c5 x7 in Black Semi Auto on steel springs 76k
now
2011 c5 x7 1.6 e-hdi egs6 black 70k - x 10
Hi All
I bought one of those reversing camera and screen kits for both my C5 . X7 and find them to be very good. £12.50 . Easy to fit as well
There are so many roads to travel but so little time, (Paul Cofield )
- My Cars: C4 Picasso 1.6 Blue Hdi 120 Manual Excl+ 2016
C3 1.2 Puretech 110 Auto Flair 2017 - x 99
The X7 lights are compromised by the mock-led look chip-cutter stuff inside the light fitting. Seems to narrow the spread of light. Turning the big red rear foglight on helps but only a bit.
I reverse down an unlit shared access to my gateway, a few years back I fixed a couple of bike-wheel reflectors to the gateposts at a handy height, helps the aim.
Richard_C
Current: , C4 Picasso 120 BlueHdi, C3 1.2 Auto
Past Citroens: Dyane (x2), 2CV, Visa, BX (x2), Xantia, Xsara Picasso, C3 (x2) C5 X7 Tourer, Synergie 1.9TD, C1
Others: Hillman Hunter, Cortina Mk 1, Maxi, VW Type 2, Granada, SAAB 900, SAAB 9-5, R5 Gordini
- Donor 2023
Citroen XM V6 (UK)
Richard_C wrote: ↑13 Feb 2019, 18:16 The X7 lights are compromised by the mock-led look chip-cutter stuff inside the light fitting. Seems to narrow the spread of light. Turning the big red rear foglight on helps but only a bit.
Sadly my home area has no facility to use reflectors of any kind. Perhaps I should mount a monster outdoor light and destroy any friendship I have with my neighbours.
Richard, you have the same car as me, although you might not have the LED Reverse lights depending on model. I have had a Xantia 2.0 HDi, XM V6, C5 MkI, all with excellent reverse lights but my New 2015 Grand Picasso (B78) is absolutely hopeless at lighting its way backwards. I have tried the rear fogs, I have tried the rear camera, all with no safe display of what is behind or where I'm going to end up. And you can't open the door because it puts the brakes on and screams blue murder.
Someone mentioned that the internal rear view mirror dimming is switch off in reverse, but I don't see this in reality, as my door mirrors are marginally brighter.
One of the pleasures of owning the "best" MPV in Britain, I suppose.
Yes, Excl+ with LEDS. Same problem. I can back my wife's C3 down the drive easily in the dark, the C4 Pic and the C5 I had before both dreadful. Tinted rear windows don't help.
I'm thinking of fitting a roof box and some kind of roof-launched parachute flare contraption. A lump of burning magnesium floating slowly down won't do any harm will it? My father told tales of landing his Baltimore in North Africa with buckets of burning kerosene marking out the runway. Maybe that's what I need.
Richard_C
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
You need one of these in the back window:
You may need som Alooooominum and sodder!
- Donor 2023
Citroen XM V6 (UK)
Richard_C wrote: ↑13 Feb 2019, 21:36 Yes, Excl+ with LEDS. Same problem. I can back my wife's C3 down the drive easily in the dark, the C4 Pic and the C5 I had before both dreadful. Tinted rear windows don't help.
Heh heh… that would scare the chickens in the back garden...
Further investigation is the order of the day, here. Thanks for brightening up my morning.
- Donor 2023
Citroen XM V6 (UK)
- Donor 2023
Citroen XM V6 (UK)
Perfect... And after I have burned the house down, I won't need the light as there will be nothing in my way any more.
Question... would it melt the tinting film in the back window? heh heh...
- van ordinaire
- (Donor 2017)
others:-
Never mind the film, more likely melt the back window!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
I don't know about melting the back window but it might bleach the retinas out of anyone following!
- van ordinaire
- (Donor 2017)
others:-
There's a guy on the Cadillac forum who thinks rear fogs (not required in USA) are an excellent ant-tailgating device, thus inspired he's mounted a laser on the back of his car which (as I understand it) projects a red triangle on the road immediately behind him. In response to the protests/uproar, he said his cousin, the Deputy Sheriff (this is in Tennessee, b-t-w) says it's fine!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
