Xantia 2.0 HDI late model with AC - radiator fans
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Re: Xantia 2.0 HDI late model with AC - radiator fans
Post by white exec »
Assume similar to XM (put me right if this isn't so)...
Two radiator fans.
Should operate in series (for slow/1st speed)
Should operate in parallel (for fast/2nd speed)
Series-parallel operation is done by the three interconnected relays up front.
Switching on AC will automatically turn fans on to slow speed (to cool AC rad).
Fans should never operate one at a time; if they do, there is either a fan fault, or a relay fault.
Fans are usually separately fused: two Maxi fuses near the battery.
Pulling the connector for the temp sensor will do as described: very brief slow speed, followed immediately by fast speed*. IIRC, reconnecting doesn't stop the fans - you need to switch off IGN and back on again to revert to normal operation. *A safety feature in case of sensor failure.
Correct circuit diag for the car will confirm.
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4917
Post by myglaren »
Or a sticking/seized fan motor.
Poke it with a stick - don't put your fingers anywhere near them as they can start up without warning.
x 1752
A seized fan will either be a short circuit
- this will cause the other fan to run at fast speed on its own, when both should be running at slow speed
- this should blow its maxi fuse, if it gets asked to run at fast speed
or open circuit
- slow speed will not happen
- in absence of this, engine will run hot until fast speed is called for
- then the working fan will run fast
Pshemsky
My Cars: XM 2.5 (1995)
Peugeot 207 (2021)
Mitsubishi Grandis (2007)
Gone with the wind...
Xantia 2.0 HDI (1999)
C5 2.0 HDI (2003)
Xantia 2.0 HDI (2000)
Post by Pshemsky »
admiral51 wrote: 09 Dec 2018, 16:57 According to the info in the post i linked to both should spin full speed when that sensor plug is removed.
I would be inclined to remove the fan that does not work and apply 12v directly to it, that will determine if the fan itself is at fault and as you have spares it should only cost time and effort, be aware that 12v will set it on full speed so keep fingers well away from the blades.
Can i ask if your aircon is working, does the compressor kick in and if so do you get both fans spinning at slow speed.?
I am used to the MK1 Xantia fan problem so as i now have a MK2 with issues i am keeping a close eye on this thread
Right. So with cold engine direction set on screen and A/C button pressed I've noticed that AC compressor not kicking in. After a minute or two one fan (drivers side) goes with full speed for about 10-15 sec and then goes off. Situation repeats every few minutes.
PS: AC system got a pressure to operate, so not sure why it won't start.
myglaren wrote: 09 Dec 2018, 17:07 Or a sticking/seized fan motor.
Tried that already - spins freely but no reaction. I had seized motor in m XM few years back, so that was a first thing which I did to this Xantia :wink:
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
Fear and Loathing in Las Vegas
admiral51
Donor 2023
Lexia Available: Yes
My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff]
x 378
Post by admiral51 »
Not sure on the above, MK1 Xantia yes, MK2 replaced the Bitron and fan activation/speed is activated by an ECU.
Info is contained Here
admiral51
Donor 2023
x 378
Post by admiral51 »
Sorry was replying to posts earlier :(
x 1752
What I described above was the classic arrangement with two fans and three relays, which were triggered by Bitron/ECU on later models, rather than the old-style 'thermo-switch' of BX and CX.
Might be a good idea, Prem, to post your VIN, so we can check RP and an exact circuit diagram, to avoid mis-diagnosis.
No shortage of advice on this pre-Christmas Sunday!
Pshemsky
Peugeot 207 (2021)
C5 2.0 HDI (2003)
Post by Pshemsky »
white exec wrote: 09 Dec 2018, 17:34 No shortage of advice on this pre-Christmas Sunday!
I'm really impressed !! =D>
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks Chris
PS: It's bit too dark now and I'm on my way to work, but tomorrow I'll check A/C fuse and one of fan's fuses for start.
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
If you have disconnected the temp sensor and only 1 fan spins, have a look at the relays between the fans in a black triangle plastic box.
Make sure they are clean and have not suffered from overloading and melted plastic holders.
If this is the case you will have to check the continuity through the system.
On my Xantia it was broken wire in the harness.
I remember much cursing when I was testing the wiring
If you search on the forum there are plenty of threads on the subject look in the a/c section.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
admiral51
Donor 2023
x 378
Post by admiral51 »
Does anyone have a link to which 2 wires need to be bridged to activate the aircon clutch and the other 2 to set the fans to full speed.
Distant memory says there are 2 thick and 2 thinner wires on the plug to the air dryer but having had a quick look on my MK2 Xantia the wires are not as identifiable as i remember :)
x 1752
Can we pull up a cooling fan circuit for Prem's VIN? I don't have one here.
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Have a read of my post from 2006 below which details a similar problem
https://www.frenchcarforum.co.uk/forum/ ... 12&t=19296
Kenny
Sorry it's a bit of read :-D
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Post by GiveMeABreak »
I’ll have a look at the circuit if it is there shortly.
admiral51
Donor 2023
x 378
Post by admiral51 »
Just a thought, this forum is awesome :)
admiral51
Donor 2023
x 378
Post by admiral51 »
This is my Vin for a 2000 w plate 2.0 HDI if that helps
Post Reply
