Lights! (Interesting and Awful please)
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1383
Re: Lights! (Interesting and Awful please)
Whatever happened to the old "must be able to place a (pre-decimal) penny over a light unit without overhanging" rule?
- NewcastleFalcon
- x 6892
Just to mop up a few examples already featured on the FCF...
The tail light has been the subject of a whatsthisthen?
Yes it was an Audi Q3 Dickie G and James (Hellrazor) came up with the goods.
NewcastleFalcon wrote: ↑17 Oct 2014, 21:07
Driving home tonight under Northumberland's dark skies spotted up ahead this take on the "designer rear lights"
I'll give you a clue its not an Alfa Romeo Guilietta, if it was it would look like this
So any tail light aficionardos out there?
- NewcastleFalcon
- x 6892
A classic in its own right
- CitroJim
- x 6207
- Contact:
Oh yes Stylish and very functional...
- xantia_v6
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
I saw a documentary a while back which covered some Ford history, and apparently the mk1 Cortina was developed at Dagenham in competition with a design team in Germany, with a committee from Ford HQ in Detroit deciding which design would go into production. The Mk1 Cortina was originally designed with wrap-around tail-lights similar to those on the Mk2 Cortina, and a full size mock-up of the design was made for the judging. Then days before the judging it was discovered that in the USA, "dustbin-lid" tail lights were the new corporate design feature, so on the night before the judging of the design, the rear corners of the car were cut up and the round lights fitted, with the paint hardly being dry when the judging panel came around. The Cortina obviously won the competition.
The Dagenham designers went back to the original tail light design for the Mk2.
- xantia_v6
- My Cars: -
There is often confusion about S1 Xantia headlights. The bad ones were fitted in 1993, 1994 and early 1995. By the end of 1995 the lenses were redesigned and they improved considerably. The late S1 lens (other than the obvious difference in external dimensions) appears to be very similar to the S2 lens.white exec wrote: ↑05 Dec 2018, 22:05 Interesting to hear that Xan I headlights suffered the same as XM on dip.
What was changed when Xan II arrived? Did things improve?
On XM (having just driven back home 20km tonight), kept being reminded that on main beam, not only do you have two very good main beams operating, but dip is on as well - i.e. 4 x 55W on main. Switch to dip, and it's 2 x 55W compromised.
On main beam, the car is night-equipped for extremely high speeds; on dip, it certainly is not.
Idly wonder what would happen if an H4 were installed in place of H1 main...? This, after all, was what BX effectively had.
I am not sure whether LHD headlight units had the same evolution.
- xantia_v6
- My Cars: -
xantia_v6 wrote: ↑06 Dec 2018, 19:24There is often confusion about S1 Xantia headlights. The bad ones were fitted in 1993, 1994 and early 1995. By the end of 1995 the lenses were redesigned and they improved considerably. The late S1 lens (other than the obvious difference in external dimensions) appears to be very similar to the S2 lens.white exec wrote: ↑05 Dec 2018, 22:05 Interesting to hear that Xan I headlights suffered the same as XM on dip.
If buying NOS headlights (e.g. on Ebay) you will find that most of the lenses on offer are the early type, but most of the complete headlights are the later type. You can fit the later lens to the earlier body.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
And then we have those made by Stickyfinger!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Onlinemyglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4924
I never had any problems with my Xantia S1 ('L'-reg sinker) lights.
The best lights though were on the GS (for the time, as Michelle points out).
However, previous cars to that were Hillman Minx, Renault 4L and a few Hillman Imps, so perhaps an unfair competition as everything on the GS was better than all the best bits of the previous cars put together. Except fuel economy
- white exec
Going back to those older British cars, many used 7" or 5¾" sealed beam units, whose typical 60/55W performance was pretty dreadful, based as they were around a standard tungsten filament. Many of us ditched them, to be replaced with same-size Hella units (available new, scrap or as aftermarket items) which accepted H4 bulbs - the newly-available halogen!
By doing this, the appearance of the vehicle was hardly changed, and the drop-in new lights were around twice the brightness, and much better in terms of beam, even at normal 60/55W rating.
Being metal reflectors with glass fronts, heat was never an issue, and so higher wattage H4 halogen bulbs could be used. My final P6 ran with 100/80 H4 halogens in the outer pair (providing main and dip) and the same bulbs in the inner pair which switched in on main beam only. Four x 100W halogen on main beam was quite magnificent . . . and in marked contrast to Rover's original 70/37.5W (would you believe!) original sealed beam jobbies.
With the uprated lights, a couple of relays and some improved cabling was essential.
This was all in 5¾" units. A few cars ran to 4 x 7" (could have been one of the large Fords, some top-spec Range Rovers, not to mention the odd Bristol). Hella had it made for years. There was a French Cibié equivalent, but it had the habit of rusting.
There's a lot to be said for round headlights, optically, but styling - as always - wins out over function . . . except for the military, that is.
- NewcastleFalcon
- x 6892
Nostalgic motoring accessories time.....Wipac hair raisers....Buckingham’s finest
- white exec
I remember Wipac. Some of the most dreadful automotive switches and connectors (especially for motorbikes), second only to dismal light fittings and bulb-holders from Lucas!
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2895
NewcastleFalcon wrote: ↑06 Dec 2018, 20:30 Nostalgic motoring accessories time.....Wipac hair raisers....Buckingham’s finest
So what's the car the person is driving in the Wipac advert ?
Sadly no longer a C5 owner
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
I might still have a pair of Hair Raisers (the poor man's Oscar) in the loft.
It was "flying pigs" (i.e. Mk4 Zodiacs) that had 4 7" lamps & the Rangies were Montverdis, or possibly Overfinches.
ONLY 400w? My 3500S (fitted with ex Polski Fiat ersatz Hellas) didn't quite make that, the only use I'd discovered for relays then was to be able to flash the foglights with mainbeam. Why? 'cos I could! My SD1 had 80/100w outers & 130w inners & a BMW 323i 90w dips & 130w mains - I remember on deserted M-ways you had to dip the lights approaching signposts,so you didn't dazzle yourself! WAS going to pull those 130w H1's forthe Xantia but understand they run too hot, so will be looking for some of those +120% jobbies - IF such trivia is ever on the menu.
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- white exec
van ordinaire wrote: ↑06 Dec 2018, 22:18 I remember on deserted M-ways you had to dip the lights approaching signposts, so you didn't dazzle yourself!
Remember that - the kickback was considerable from those huge and highly reflective signboards.
Despite high-wattage halogens, most of those round lamps produced very little dazzle, as the dip beam was well controlled. In marked contrast to what we have today.
