Unfortunately they are not PSA part numbers, so are likely to be some internal manufacturing numbers printed on the assembly themselves.
However, if it helps, there are only one set of part numbers for these right hand drive Xsara I and Xsara II conrod assemblies and motors and one set of part numbers for the left hand drive models. So if those parts are from a RHD Xsara II it should fit
Broken Wiper Linkage
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: Broken Wiper Linkage
- (Donor 2021)
- My Cars: Xsara 2.0HDi 90
- x 10
Thanks - thats what I was hoping. Mechanic told me as they where MkII assemblies they would not fit my car as mine was a MI.
I'll get the best out of these.
I would love to upgrade to variable intermittence wipers, but I don't suppose that that is easily done?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Well as said, the actual mechanical assembly and the motors are the same, so this feature would be down to the Comms unit board / BSI variant I suspect.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
When my daughter ran a Xsara her wiper assembly broke down. I got a replacement off ebay for about £20. Here's a pic of the old one. You can see the ball joint that's come adrift.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- (Donor 2021)
- x 10
Yeah, that's the same failure point as mine.
Shame about the intermittent wipers - its one of the things I miss the most when switching back from other vehicles.
One of the pivot arms that operates the wiper on my Dispatch has seized, resulting in the linkage keep popping off.ordered a second hand one from eBay, as new they are 220 odd quid. I sent seller an email asking if this one had free movement, lo and behold it was seized too, but they managed to strip it, clean and lubricate, and all working now. Like every job on Citroens, p i t a to do.
Cheers Rich
- (Donor 2021)
- x 10
I'll figure it out, but can anyone tell me how to remove the plastic converting the front wiper linkage on the xsara?
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
Only what I said before:
From memory (ours went a good few years ago) you have to take the top panel off. It's held in place by plastic clips which mostly broke when prised away. Try to preserve as many as possible they are NLA now. I found a clip off some other vehicle and then used double sided sticky to complete the job.
- (Donor 2021)
- x 10
Thanks. I made a puller from some scrap box section and a bolt to get the arms off.
I don't suspect that a heat gun would help protect the clips? It's a bit cold here which would not help the brittle clips.
- (Donor 2021)
- x 10
Must take a bit of force to remove those clips. Sorry, not sure how I missed your first post.
- (Donor 2021)
- x 10
Broke half the clips taken the cover off. All on now and a good job.
- Paul-R
- Donor 2023
Well done. Little b*stards, aren't they!
