Thanks Marc. I had wondered about a repetition on the Pug 508 of all the woes associated with X7 steering racks on the C5.
I've not seen any mention in other Pug places of this rack issue so I presume it only affects the early X7 model of the the C5, trust Citroen to cock up the redesign . I'm loosely researching a replacement for my Xantia estate which is approaching its 20th birthday.
x7 steering rack - Gone again
- My Cars: C5 2.0 (163) diesel Exclusive Tourer 2010
Xantia Exclusive HDI Estate - x 27
Re: x7 steering rack - Gone again
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (119,290miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
GiveMeABreak wrote: ↑12 Jun 2019, 10:54 They are similar, but have different part numbers on a comparison using the same engine for example (DW10BTED4 with particle filter). Unfortunately as there are a multitude of rack part numbers for the X7 - it would take too long to cross reference every one. They are different for the engine types / power steering types etc., so you have a stack of options before you start comparing. There is no way to tell what the differences are as they are visually very similar.
Which is why I went for a reconditioning of the cars rack rather than a a "second hand" recon unit.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
If they're visually similar then surely they might suffer the same problem if the pinion is in a position where it's exposed to wet?
- Stickyfinger
AX, little Daffodil
- Contact:
Marine grease is you friend.....BIG dollops of it.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Ditto that - bought 2 tubs of white Marine Grease at the time.
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Well guys,
Rack fitted so much easier with subframe removed allowing good access to fit the pipes onto rack etc. Rack feels tighter but that maybe due in part to, new wishbones and drop links fitted.
Handling and ride much better more like a citroen.
Hopefully no more dramas for a little while.
Kenny
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Well done and fingers crossed Kenny.
