Hi Marc, I should practice what I preach, I was suspecting a burnt circuit board in the bsi unit, So I took it out and took it apart, no burnt area's . So I decided to check the fuses while it was on my desk, These are the fuses that my brother swears he had checked, sure enough a 20 fuse had blown, put it all together and it fired up, perfect. many thanks for the help.
Completely my own fault, do not trust anything my brother tells me.
Paul
C2 cranks but no start
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C2 cranks but no start
Excellent - pleased that’s sorted and a cheap repair! I think your brother owes you a pint or two.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1382
Asking again.
The key was falling apart, No i taped it up with insulation tape.
Paul
Paul
- Paul-R
- Donor 2023
Did it work at all after that?
When i changed the fuse
- Paul-R
- Donor 2023
Yes but did the car start at all after you taped the key back up?
The key was not the problem, The problem was the blown fuse on the BSI module
