I'm after a ser myself as they look like really useful things. How about this set?: https://www.ebay.co.uk/itm/OPEN-FLARE-N ... SwpINZX6h1
I know for a fact that I'll need new brake bleeding nipples for my rear callipers next time I bleed them as I nearly rounded them off tightening them up last time with a normal spanner! In hindsight I should have used a socket at least.
Brake pipe nut sizes
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
Re: Brake pipe nut sizes
And to think all i wanted to Know what size spanner to get! so know about as much as i started with?
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
At least you know what you don't know now.
- white exec
- x 8
I got the set above a bit cheaper than that set!
the other thing i need to know is those clips(i presume clips)that are around ends of flexible are they part of body/arm or do they move/unclip etc out of the way?
OK something weird happened.
I posted a reply to this, yesterday, but it hasn't appeared.
Short answer to the original question is the nuts will most likely be M10 fine thread and require a 10mm, or 11mm spanner, which should be a "flare nut", or "brake pipe" spanner, not a normal open end.
No idea why my original reply didn't work...
Sparksie
2000 Xantia 1.9TurboD
- white exec
