Citroen C5 X7 09 plate limp mode
Re: Citroen C5 X7 09 plate limp mode
Both magnets are in place it looks like the reed switch is knackered so will need replacing either way what about you Marc do you think it's worth a try??
- x 1757
Reed switches (and their magnets) are extremely cheap.
Take care with orientation (N-S) of the magnet, as it can affect the action of the switch. Test first.
Those resistance values are curious: 150k open, 15R closed. Would expect infinity and near-zero, unless resistors are also included.
Ok chaps put a Reed switch on the fuel filler cap cleared the fault codes and all running a sweet as a nut cannot believe that's a little switch like that could cause so much trouble. I would like to thank you all very much for your help in this it is very much appreciated I am now one happy chappy
- x 5296
Delighted you fixed it so painlessly and for far less that the dealer would have extracted from you - where on earth do they get their prices from?
Jim always says they have a random number generator in the accounts department
- x 6918
Indeed, it’s a lot for a few wires! Glad you have a cheaper fix!
