Yep, swapping of the fuel pump in the process has to be prime question mark over why it's now over-fuelling (black smoke).
Do you still have the original Lucas fuel pump? Was it still working?
If so, might be worth swapping back to that and see what it's like then.
Overheating, overboosting, black smoke! Urgh!
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Re: Overheating, overboosting, black smoke! Urgh!
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- Pug_XUD_KeenAmateur
- (Donor 2018)
- My Cars: 405 naD Est
- x 232
PS: dead giveaway if the Thermostat's stuck closed.... the Rad will remain cold despite the engine temp
Puxa
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
On my S2 Xantia, late 1.9 td the fans did not kick in until 95 degrees, I was used to my BX fans chiming at 88 degrees and until I realised I was pulling the brown connector off the thermostat housing to force the fans, I only found out when on a busy motorway I watched the temp climb to 95 and then they kicked in.
