I will remove silicon and tighten clamp over the weekend and see how it goes.
Thank you so much for help, much appreciated.
Hydraulik pipe leak
- My Cars: Citroen C5
- x 6
Re: Hydraulik pipe leak
Could be the # 5 hose on the diagram (F) Return pipes Rear replaced by a "generic fuel line hose"? AFAIK the fuel hoses could make few bars and are gasoline resistant. LDS fluid should not be a problem? And any bleeding of the hydralic system is nessesary after replacement? Thanks for sharing the info
