Has my x7 suspension dropped?
- Bandit12
- My Cars: C5 X7 diesel exclusive
- x 12
Re: Has my x7 suspension dropped?
Thanks Marc. I'll pop her up on ramps, remove the undertray and have a look. On a completely separate note. As I'm raising car up I'd like to change auto gearbox oil on my AM6. I've identified right oil, any idea how many litres I need to buy?
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Yes, remember you can only do a partial change. Total capacity for a dry gearbox is 7 litres, so you can only drain 3 litres out, leaving 4 remaining. So you can replace 3 litres at each oil change time. So leave it for a month or so and then repeat procedure and again to get as near as you can complete change.
For the AM6 drain and refill procedure, see my post here:
viewtopic.php?f=3&t=56837&p=517292#p517292
- Bandit12
- x 12
Thanks Marc n yes planning on changing oil a couple of times. Thanks for the link. One question re which oil as bit confused. I thought I needed Mobil 3309?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
It depends on the Euro rating of the engine. Can’t remember if I have your VIN previously, but PM me and I’ll check your engine rating and the right oil you need.
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Marc please could I have the answer too? I need to drain my AM6
VF7**************[VIN obfuscated, can be read by forum staff]*******
many thanks
Bandit if we are the same should we buy in bulk?
John
edit. suspect the oil will be different
many thanks
John
Reason: VIN Masked (Got it already John)
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi John, your car is Euro 5, (DW10CTED4) built 2010, so needs the AW-1 Oil NOT the JWS 3309.
Your Engine is stated as Euro 5 Emissions standard too.
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
greaTt, thanks Marc
this looks ok and quite cheap?
https://www.ebay.co.uk/itm/ATF-AW-1-Ais ... 53094?var=
- Bandit12
- x 12
Hi Marc and John
PM with VIN sent to you Marc and yes John if the oil is the same spec then I'm happy to order bulk if it saves money. If memory serves then other consumables like drain plug and seal will need to be ordered too.
Bandit
Bandit
I have suggested here before that one could try 'padding' a worn height corrector with a resistor of, say, 10% of the total track value, thus moving the operating point, then adjusting the height accordingly. I have to point out that I've not tried this, having got away with cleaning them, but worth a try if you'd otherwise replace the corrector.
- Bandit12
- x 12
Hi John, Sadly my car is Euro 4 and takes JWS 3309 so we wont be able to get a bulk order and save a bit of cash
Interesting idea Dsney, I'll pop the car up on ramps when I'm back from honeymoon and check out the sensor.
ttfn
Bandit
ttfn
Bandit
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
^ Usual precaution about supporting the car independently first, if working on the height correctors.
To be honest though I never really heard of these being repaired - they are uber sensitive. Current price for your X7 rear corrector is part 5273J9 and £60.02 inc. VAT Gino.
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
dnsey wrote: ↑28 Aug 2018, 21:14 I have suggested here before that one could try 'padding' a worn height corrector with a resistor of, say, 10% of the total track value, thus moving the operating point, then adjusting the height accordingly. I have to point out that I've not tried this, having got away with cleaning them, but worth a try if you'd otherwise replace the corrector.
That's a very interesting solution to the problem, and one I may have to explore in the near future
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I remember Trainman having an issue with height correctors on his C6, and I found (somewhere in this forum) a thread where somebody had (carefully) opened up a height corrector (it may have been for a C5, but they were similar). It turns out that that, while the pins are square, the holes they go into are round, and whoever did the soldering was somewhat sparing with it. On the thread I found the person re-soldered the joins (making sure they had plenty), and that seemed to get the height corrector working properly.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
My oil arrived today .6 or 7 litres .. I may try the first drain on Friday Eve .
Interestingly the car no longer changes to 5 or 6 automatically as of last week. Well not very often.
will it change. Manual shift is still ok. Will report back on things
- EDC5
- x 120
Which oil did you go for in the end?
That's very odd, I also had an occasion this past week where the gearbox failed to change into sixth despite being on a dual carriageway at 70. Still, it must have had a reason!
