ES9 V6 Transplant Immobiliser Question
x 1109
Re: ES9 V6 Transplant Immobiliser Question
Unread post by xantia_v6 »
Those pages appear to be for a Xantia V6 Mk1 Automatic. If your wiring is from an XM or Peugeot, the locations and wire numbers will be different.
On the schematic, the keypad is number 8200 at the bottom right.
x 1109
I just looked at the wiring on my XM and Xantia, comparing to your photo, and I am fairly sure that your engine did not come from an XM, as some of the wire colours and locations are wrong. It could have come from a Xantia, of perhaps Peugeot 406, we would need to see the power steering/hydraulic pump to get a better idea.
The part number for the ECU of an XM ES9 with automatic transmission is: 96 255 523 80
The part number for a Mk1 Xantia V6 with automatic transmission is: 96 255 527 80
What is the part number on your ECU?
enrz
Unread post by enrz »
Hi all
I succeeded
special thanks my dear friend :xantia_v6
in the last night 23:30
i can run my engine
through manually programming by myself.
thanks a lot to every body who help me.
yours Sincerely : En.Ramezanian
enrz
xantia_v6 :
my ECU number is 96 255 528 80
x 1109
enrz wrote: 22 Jun 2018, 08:52
xantia_v6 :
That is the ECU number for a MK1 Xantia (or 406?) with manual transmission.
An XM with manual transmission uses 96 255 522 80.
The reason for determining what model your ECU came from is that it confirms what type of immobiliser was fitted. In this case it was a keypad. It also tells us that the wiring diagram you have posted is correct for your engine and ECU.
enrz
hi every body
I success !!!
i can kill Immo and Neutralize the keypad
and Run my V6 Engine
Thank you all for help me
i Install This Engine to "Samand" Body-(Product of a car maker Company in iran)- and Run it .
then i can change O2 parameters to reduce fuel consumption.
0 to 100km in this car is less than 5 second!!!!!
i can help you about this engine .
Reason: Removed personal information
