Looking at that, I am fairly sure that the seal comes out and goes in from the top, no need to disturb the bearing (and maybe no need to dismantle the rack).
C5 X7 Steering Rack - Again!
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
Re: C5 X7 Steering Rack - Again!
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2889
'fraid not there's a 2-3mm lip on the casting and the seal sits under that. If it wasd a flexible seal then it'd be possible to put it in from the top, but it's a classic rigid oil seal so can't be persuaded into place from the top
I've got the housing sitting next to me here so if anyone wants better photos then I'll dig out the grown up camera and take some better shots.
Sadly no longer a C5 owner
- xantia_v6
- My Cars: -
OK, assuming that it is a steel bearing in an aluminium housing, it should be easy to remove the bearing by heating the assembly to about 150 degrees C and let differential expansion do the work.
- bobins
- Donor 2023
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2889
OK, that'll be gas mark two and a half and don't tell the Mrs I'll give it a go tomorrow. By the way, what temperature do oil seals melt at ?
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
That lug is a pain in the backside being there.........is it a solid lump ?
I see that lump as the ideal fixing point for a gator...I have a plan forming in my little bit of grey matter.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- bobins
- Donor 2023
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2889
Yep - a solid lump, but with a drilling all the way through to take the stud.
As an additional note, the top of the casting is only just parallel to the sides i.e. it'd be a little bit of a pain to get a positive fix of some form of cover onto the casting and use something like a jubilee clip to hold it on - the more you tightened the jubilee clip, the more the whole lot would want to slip off the top of the casting.
OnlineSloppysod
- My Cars: Citroens
1 x GS, 1 x GSX (Banger raced), 1 x GSA,
2 x CX Famililles, 1 x CX GTI,
BX, XM, Xantia, C5 Mk1,
C4 (Coupe), C4 (B7),
C5 (X7) - RIP April 2024
Renault
R4 Van
Fuego
Clio Campas - x 216
Delugging the rack is a good idea, however, you can, I did, fit the boot over the lug and secure with a tie wrap and left the top to sit snug over the floor boot.
I also agree that leaving it without a tie-wrap could leave it open to the environment, but then again it may well help to let air circulate and keep it all dry, it's a personal choice and we will not know which is best for a few years (if ever).
The problem with corrosion is that to stop it you need to completely remove it so sanding down and painting, like most refurbished racks, is only a short time measure, so the Lithuanian guy who turned his spigot probably helped the situation, providing he removed ALL the corrosion and retreated afterwards.
I am not sure about the double seal mod, if the rack is allowed to corrode then surely it will eventually wear out both seals, again only time will tell.
Stu
Major interventions
C5 Steering rack @ 58,000 mi
4 discs & Pads @ 63,585 mi
2 (AM6) oil exchanges @ 58,876 & 72,378 mi
Major interventions
- bobins
- Donor 2023
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2889
I think there may be an element of 'red herring' with the double seal mod. I think it's nothing more than an R23 seal instead of an R21 seal. OK, so an R23 seal has double the seals (!) but there's only about 4-5mm between the two lips and, as you say, they'll both wear out soon enough if the shaft rusts.
- white exec
Looking at several of the photos of the lump and the pinion casting, I wonder whether it might be possible to just slice off the outboard end of the lump - by a 'vertical' sawcut made parallel to the pinion shaft - so a modest diameter gaiter can be slid over the remains of the lump, and properly clamped on to the curved 'waist' below the lump.
Some more photos of the lump and its environs, from all angles, would help.
I see no advantage at all in not greasing the pinion shaft, and encasing it in a properly sealed gaiter. If weather can't get in, there will be no rusting. The part of the pinion shaft below the seal (inside the rack) is made, presumably, of the same steel, and that doesn't rust. (I'm amazed that a chunk of steel capable of being worm-cut, and presumably case-hardened, can suffer such appalling and destructive corrosion.)
All this is, perhaps, one for John on club-xm; his professional expertise was partly in metallurgy.
- Stickyfinger
AX, little Daffodil
- Contact:
As was mine....mostly materials used inside the human body mind you.
- xantia_v6
- My Cars: -
white exec wrote: ↑11 Jun 2018, 22:19 (I'm amazed that a chunk of steel capable of being worm-cut, and presumably case-hardened, can suffer such appalling and destructive corrosion.)
A minor technical point, but this piece of steel does not have the pinion teeth cut into it. The shaft is made up of two pieces joined by the torsion spring.
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Yep, they will only have case hardened where the teeth are cut.
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- white exec
OK, thanks; didn't realise that the shaft was a two-part assembly with springing.
Can the parts be separated?
- xantia_v6
- My Cars: -
white exec wrote: ↑12 Jun 2018, 12:31 OK, thanks; didn't realise that the shaft was a two-part assembly with springing.
I expect so, but it would upset the calibration of the pinion valve, so not a diy excercise.
