Magneti Marelli rt 4 problem
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Bibiqn
Re: Magneti Marelli rt 4 problem
Post by Bibiqn »
GiveMeABreak wrote:
24 Apr 2018, 14:31
Good luck - if this fails, your only other option is to send it to MM for a repair or find a specialist who can reprogramme the EEPROM chip for you and do the update.
Yes thanks to all
Bibiqn
Post by Bibiqn »
GiveMeABreak wrote:
24 Apr 2018, 14:31
I do everyting what you say me
But no have progres.I
I decided to do something else.i try to change display at tip B two colors.and buy a new standart multymedia with touchscreen.But i don t no conectors is the same.
Thank you to try help me.
Have a nice day friend.
EDC5
Donor 2020
x 104
Post by EDC5 »
Bibiqn wrote:
24 Apr 2018, 16:25
GiveMeABreak wrote:
24 Apr 2018, 14:31
Have you decided to buy a new head unit?
Bibiqn
Post by Bibiqn »
EDC5 wrote:
24 Apr 2018, 21:13
Bibiqn wrote:
24 Apr 2018, 16:25
GiveMeABreak wrote:
24 Apr 2018, 14:31
In fact i dont no what to do.
EDC5
Donor 2020
x 104
Post by EDC5 »
Bibiqn wrote:
25 Apr 2018, 04:44
EDC5 wrote:
24 Apr 2018, 21:13
Bibiqn wrote:
24 Apr 2018, 16:25
I have seen a cheap(er) RT4 on eBay:
https://rover.ebay.com/rover/0/0/0?mpre ... 2939633223
It may be easier than trying to fix the old one if there is an issue with EEPROM.
Bibiqn
Post by Bibiqn »
EDC5 wrote:
26 Apr 2018, 21:05
Bibiqn wrote:
25 Apr 2018, 04:44
EDC5 wrote:
24 Apr 2018, 21:13
I find device.Citroen C6 but i dont know is rt4.the seler tell me it is rt3 but look like rt 4.i upload picture to help me what is is.
Trainman
Donor 2018
x 12
Post by Trainman »
the quickest way to tell the difference between RT3 and RT$ is, RT3 holds the maps on a CD, whilst RT4 has a HHD for music and maps
Bibiqn
Post by Bibiqn »
Trainman wrote:
28 Apr 2018, 13:29
I know.but this device i buy at damaged car.the seller cant try device.the car not work.
I hope toy understand me.my english is not good.
MikeT
x 187
Post by MikeT »
The label says it's an RT3 X6 N3
Trainman
Donor 2018
x 12
Post by Trainman »
according to my tame expert, this is an RT3 Evolution which is essentially the RT4
Trainman
Donor 2018
x 12
Post by Trainman »
If it has fibre optic then RT3 also only antenna socket plus two fakra for GPS GSM
The evolution has a row of 4 fakra connectors different colours, and a 30gb
Bibiqn
Post by Bibiqn »
Yes and i thing so.if have 4 colours conector is rt 4.but ther seller say me its rt3.i m confused.
he does not write anywhere have a hdd.
Trainman
Donor 2018
x 12
Post by Trainman »
Basically it's RT4
Bibiqn
Post by Bibiqn »
I understand.thank toy guys
x 2773
Post by GiveMeABreak »
Guys this is probably NOT compatible with the C4 Picasso. That is an older system. The RT4 that went into the C4 Picasso is similar to the RT4 used in the early X7.
