Wiring diagram for xenons - 2007 mk1 facelift C5
Harlequin
Donor 2023
My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6
x 24
Re: Wiring diagram for xenons - 2007 mk1 facelift C5
Post by Harlequin »
thank you sir.
so , IMO, I need 7715 and 6606 and there's an extra loom runes from PSF1 (9 and 10) to each light and a loom run from the bsi to 7715 (assuming thats the suspension pump) and 6606 is the light ecu.
is 78-- related to tyre sensors (I know it says esp)?
most looks at my unprofessional glance to be very similar; ofc mine doesn't have tyre pressure sensors.
Simon
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Post by GiveMeABreak »
Some extra info - Flow Chart for Directional Lighting
Directional Lighting Flow Chart
Single arrow: Wire connection, Double arrow: LIN connection, Triple arrow: Multiplexed connection
CodeDescription
BSI1 Built-In Systems Interface
BSM Engine Fuse Box
CV00 Switch Module At The Steering Wheel
0004 Instrument Panel
1320 Engine ECU
1630 Automatic Gearbox
2610 Left-Hand Headlamp
2615 Right-Hand Headlamp
5007 Rain/Brightness Dual-Function Sensor
6606 Directional Headlamps ECU
7715 Suspension ECU
7800 ESP ECU
DescriptionPower consuming equipmentConnections
1 Engine running statusDirectional headlamps ECUCAN
2 Gearbox ratio engagedDirectional headlamps ECUCAN
3 Status of the dynamic lighting. Status of the automatic height adjustmentBSI1CAN
4 Engine running status. Gearbox ratio engaged (if automatic gearbox). Reverse engaged (if manual gearbox). Vehicle speed. VEHICLE RIDE HEIGHT. Steering wheel angle sensor information. Status of the lighting controlsDirectional headlamps ECUCAN
5 Supplier’s specific networkHeadlampLIN
6 Concealing flaps control. Additional halogen main beam headlamps controlHeadlampAll or nothing
7 Request for switching on of the directional headlamps. Main beam/dipped beam headlamps request (concealing flaps)BSMBody CAN
8 Directional headlamps fault statusBSI1Body CAN
9 Main beam headlamps fault status. Information on brightness. Steering wheel angle sensor information. Status of the lighting controlsBSI1CAN
10 Directional headlamp height adjuster fault. Request for switching on of the directional headlamps. Main beam/dipped beam headlamps request (concealing flaps)BSM Body CAN
11 Information on brightnessBSI1Body CAN
12 Direction of rotation of the steering wheel. Initialisation of the steering wheel angle sensor. Status of the lighting controlsDirectional headlamps ECUBody CAN
13 Light indicator lamps controlInstrument panelCOMFORT CAN
14 Status of the dynamic lighting. Status of the automatic height adjustment. Directional headlamp height adjuster faultBSI1CAN
15 Deactivation of the dynamic lighting. Status of the dipped headlamps. Steering wheel angle sensor information. Information on brightness. Status of the lighting controlsDirectional headlamps ECUCAN
16 Vehicle ride height informationDirectional headlamps ECUCAN
17 Vehicle speedDirectional headlamps ECUCAN
OlegR
My Cars: Citroen Pluriel 1.6 SensoDrive 2004
Citroen C5 Estate 1.8 manual 2005
BMW M535i '87
Post by OlegR »
What's the end of this story?
In my setup, I don't have only the 6606 Directional Headlamps ECU
having experience converting my old '86 BMW from ECU Motronic 1.0 to 1.3 from a '94 7 series, looking at the diagrams it's doable.
Need to wait for the summer and find the missing ecu+connector, and the diagram for my car, and will try it.
Post Reply
