Lexia unable to communicate with ECUs
Rhothgar
Donor 2023
My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new)
x 81
Re: Lexia unable to communicate with ECUs
Post by Rhothgar »
GiveMeABreak wrote: 19 Feb 2020, 20:47 Possibly. DON'T let it connect to an active internet connection, or it will deactivate and possibly block your unit.
That's worrying then! Jim's instructions state ensure ALL internet connections are on! This is presumably only for installing Diagbox but I didn't realise that at the time.. I've already run Diagbox with the internet connections enabled though I have not connected it to a car yet.
How would I know if it is blocked and is this why Jim tells you to save a copy of the licence file to your desktop?
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Post by GiveMeABreak »
Yes.
Becase when you undertake some procedures it will ask for an ID, then it generally connects up to the servers and will deactivate. I’ve seen it do this loads of times.
Rhothgar
Donor 2023
x 81
Post by Rhothgar »
GiveMeABreak wrote: 19 Feb 2020, 21:50 Yes.
I take it that it's not wise to add your Service Citroen login then... :shock:
Donor 2023
Lexia Available: Yes
My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone)
x 1381
Post by Paul-R »
Rhothgar wrote: 19 Feb 2020, 21:34
Jim said that to me as well and I did confirm that it doesn't matter. Today when I was playing with the 308 the Connecting to Server box came up many times and I just clicked on the red cross (twice) to decline with no ill effects.
"Trying is the first step towards failure" ~ Homer J Simpson​
C15 Romahome White
CX 20 Polar White
x 5742
The issue is not that - declining is the right thing to do - but depending on the procedure you are undertaking (and to be specific, I'm talking about ECU configuration), where it asks to identify yourself and if you then decline it cancels the procedure and deactivates Diagbox.
Don't ask me what procedures - it varies and depends on the type of operation where it would usually ask for the technician's ID and log in.
This won't be a problem for most of you though with fault reading and clearing.
Donor 2023
x 1381
Post by Paul-R »
I have another problem in that case. There appears to be no hotkey or slider switch to turn the WiFi off.
If the installation is deactivated then is it just a matter of copying over the saved copy of appdiag.sys?
Rhothgar
Donor 2023
x 81
Post by Rhothgar »
GiveMeABreak wrote: 20 Feb 2020, 01:14 The issue is not that - declining is the right thing to do - but depending on the procedure you are undertaking (and to be specific, I'm talking about ECU configuration), where it asks to identify yourself and if you then decline it cancels the procedure and deactivates Diagbox.
So if you accidentally somehow find yourself in this situation, do you just give it a look like Peter Griffin who doesn't want to be noticed, switch off the internet and slowly back away from the laptop on tip toes?
If you decline you're shot, if you accept you're shot! Damned if you do! Damned if you don't!
I suppose an 'internet crash' is the only solution. Would love to know for that moment of realisation when I find myself in this position. Again, perhaps this is why Jim clearly states save your licence file. I've no idea.
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4922
Post by myglaren »
Paul-R wrote: 20 Feb 2020, 08:38 I have another problem in that case. There appears to be no hotkey or slider switch to turn the WiFi off.
There should be an icon somewhere to manage wifi connections.
The one next to the ✅
Donor 2023
x 1381
Post by Paul-R »
True.
Hmm, I wonder if I can set the router up to bar requests to whatever URL PSA uses?
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
x 4922
Post by myglaren »
Turn the router off while you work, block any others on your list to prevent any unwanted connections.
C15 Romahome White
CX 20 Polar White
x 5742
All you need to do is disconnect from the active network connection and ensure that 'Automatically Connect' is not ticked when you next connect and log in with the password, so it doesn't auto connect back up later. That way you can leave your Wi-Fi / network adapter enabled at the hardware level. This isn't a problem usually for dedicated diagnostics laptops as you should rarely need internet access.
Rhothgar
Donor 2023
x 81
Post by Rhothgar »
I have a feeling that Jim’s setup procedure prevents them because I did a clean Windows install and the Wi-Fi will not automatically connect at all. I have to disable the adapter, re-enable it then press Fn+F2 to initialise the wireless adapter on my laptop and then refresh and networks come up. It’s a right pain but possibly a fail-safe he may have had written in to 7.57?
Rhothgar
Donor 2023
x 81
Post by Rhothgar »
I also read somewhere that the Lexia will read Mitsubishi. Does that need separate software? Reason I ask is we have a Smart as a runaround At the moment and I believe they are Mitsubishi engines.
C15 Romahome White
CX 20 Polar White
x 5742
I think that is because the Citroen 'C-Crosser' is basically the Mitsubishi Outlander and they use Diagbox as it is basically the same vehicle. My understanding is they actually select C-Crosser as the vehicle, so won't work with other Mitsi models.
Post Reply
