Cam belt snapped on Peugeot partner please help!
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2513
Re: Cam belt snapped on Peugeot partner please help!
The factors supply them in kits, got mine from my usual factor here:
If you scroll down and click on the 'Parts Alliance' link it will almost certainly list a supplier near you.
http://www.gmfmotorfactors.co.uk/
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1205
I think his is a 1.6 Richard, I can't see any listed for that but there are loads of 16 valve ones, don't know if they are the same?
Cheers, I’ve tried that code and it seems to cover earlier years too, it also says (9HN) what does that mean?
'13 3008 1.6 HDi GripControl - x 997
Same ones are fitted to lots of DV series engines by the looks of it Peter, both 1.4 and 1.6.
Bit of an update guys! First off thanks for all the help so far!
So I’ve stripped the covers off and taken the cam out and all 8 rockers are broken and one of the valve spring tops has come off, looks like one of the rockers had got caught in there compressing it making the collets fall out, I’ve clamped my cordless drill onto the valve and spun it around I dont think it’s Bent but it’s hard to tell, is there a way to compress and refit the springbwith the head still on?
I’m wondering if it’s worth just taking the head off and checking it all out it it much of a job?
Turned out the water pump seized solid.
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
('96 ZX 1.9TD SX, ??k roller due to collect at weekend) - x 214
Bit of a mission pulling the head off if there still may be no damage, perhaps you could take the injector out and feed compressed air in through the hole to hold the valve up while you carefully refit spring/collets. It'd require some adaptation of either a scrap injector or diesel compression test adaptor to fit on an airline but would certainly give a better idea of if the valve is bent or not, since you'd hear massive rush of air escaping if it's not sealing well.
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, ??k
JayRenton wrote: ↑13 Mar 2018, 14:40 Bit of an update guys! First off thanks for all the help so far!
I had the same problem with mine, a bit of a struggle but you can put the spring and collets back on without taking the head off, if you pull the injector out and feed in a bit of rope or similar (I used a bit of flat plastic telephone extension cable) on top of the piston then bring it to the top it will hold the valve in place while you refit the spring etc. Mind your language
That would be a preferable option yes, I forgot if it was possible to do the rope trick with these or not (suppose being direct injection should've given me a clue!)
Cheers that’s put my mind a rest then, I’ve ordered the parts picking them up in the morning.
What can I use to compress the valve spring? The usual tool is like a g clamp I’m thinking? Usually with the head off?
Actually I think I can fabricate something I’ve got an idea!
Actually, since this is an "interference" engine, simply putting the piston at tdc should hold the valve sufficiently closed to enable you to fit the collets, provided you can compress the spring. Be careful not to exert much force on the valve stem, as the head will be sitting directly on top of the piston. The pressure you could conceivably apply may be a lot more than it took to break the rockers, especially as the shock of that impact will have greatly magnified the forces actually applied! Try pushing a panel pin into a picture frame, without swinging the hammer. You'll most likely smash the frame!
However, with care, it should be possible to do this without removing the injectors. I believe disturbing as little as possible is the right course, because it removes possible causes of any misfire that may be apparent on reassembly.
Sparksie
2000 Xantia 1.9TurboD
Thanks! That’s good advice and make perfect sense!!
Bit of an update guys I’ve managed to refit the valve spring today luckily and started bolting it all back together.
This might be a silly question but I’ve rotated the crank and fitted a 5mm drill bit in there so does that mean It’s in the right position to time it back up? I still need to tighten down the camshaft but I just wanted to check first basically If the crank rotates 360 degrees would it go back to where it started?
It would be best to set the crank with the pistons down the bores, bolt the camshaft down and time it, then carefully advance the crank to the timing position to avoid any potential valve / piston contact. Trouble is, I've no idea if the timing position is at TDC on one of the cylinders or not.... Only easy way to find that out would be to remove the sump and watch the big ends - unless you could get in there with a small borescope via the sump drain and see one of the big ends.
Note also that you may have trouble starting this - Lighty says he often has to tow start 1.6 HDis after head work as the oil drains out of the tappets, and the starter is not fast enough to rebuild the pressure.
I think my head is going to explode lol!
I’m pretty sure that I had to rotate the crank from it’s pinned position for the piston to hold the valve up while i re fitted the spring/collets! Which would indicate that the pistons could be at mid bore when pinned for timing up in these engines!
I just cant remember if I had it pinned in the flywheel or by the crank pulls!
Does anyone know the position of the pistons on this engine when locked for timing up?
Thanks James
Thanks James
