C5 (X7) Component Failures /Faults / Replacements Poll
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: C5 (X7) Component Failures /Faults / Replacements Poll
Just had my passenger window regulator go now - I didn't include a separate item on the component list, but that's both front ones that went on mine. First was replaced (compete original motor / regulator kit) by Citroen at over £500 cost and now the passenger one! So another job to do this month.
- Donor 2023
- My Cars: Citroen C5 HDi 2.0
I bought an 08 Estate 3 yrs ago and have had to replace driver side window regulator (great advice from you guys), steering rack, a/c compressor and nearside window wiper motor. Not too bad for a 10 yr car but still put £1000 on the purchase price.
- x 3
Had a really weird one on my C5 just before Christmas - the fuel cooler in the return pipe to the tank sprung a leak.
If you've never seen one it looks like a small version of what you'd see on the back of a fridge!
And of course it's a dealer only part, though my local indy. got one within 48 hours.
- My Cars: 2012 C5 1.6 petrol turbo auto exclusive - La Grenouille Noir
1990 Range Rover Vogue SE 3.9l Auto - La Range
Previously a couple of early C5 V6 autos
Hi there,
I bought a second-hand C5 X7 with 80000 kilos on the clock (LHD I live in Brittany!).
It is a 1.6 turbo petrol with 6 speed auto box, I don't do "oil engines" sorry, even La Range is a 3.9 petrol V8 (16 MPG regardless).
My previous C5s were both 3 litre petrol V6 auto.
Now the faults on the X7.....
First fault was the passenger side heater control died, still not fixed it.
Couple of weeks ago I got a pretty engine picture and a "Repair needed" notification.
Getting a bit long in the tooth to decipher fault codes, I started work as an apprentice at Morris Commercial in Birmingham in 1961, the other vehicle; La Range, only has two ECUs ( Injection and ABS) everything else I can cope with!!!
The timing chain was loose - it had stretched, never seen it before said my local main dealer, i am 1200€ worse off!
Otherwise it has done 2 lovely years and another 15000kms.
- mickthemaverick
- My Cars: 70+ former cars (list available) including 11 Citroens, 3 Renaults
Current cars: 2004 Subaru Legacy 2.5 SEn, 1994 Mazda MX3 - x 6066
Marc, I don't know how the poll software works as I have not played with it but is it possible to add another couple of columns to your poll for MK1 and Mk2 C5's so that we can actually see the differences as time moved on?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Not really Mick, it doesn't allow for multiple recording. I was going to do one for the earlier models - but never got round to it and by the time I did, thought there was little point with there being fewer and fewer owners with them here now. I created the X7 Poll initially because of the unusual number of rack failures that were becoming apparent and then struts....
- mickthemaverick
Right I see, fair enough, thanks Marc.
- Gregor
- My Cars: Actual fleet:
- C5 III tourer 2.0 HDI RHF (103kW 2010)
- P208 XY 1.6 THP (115kW 2013)
- GSX-R 750 (110 kW 2008)
Past members:
Xsara 2.0 VTS (2001)
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
Zastava 750 (1968) - x 14
This list is more and more "blue" checked on my display! It must of been some feast for drunk workers when they made my C5x7... worst car ever had regarding faults and errors.
Driving Citroen is a diagnose!
- (Donor 2021)
- My Cars: Current - '09 Citroen C5 Exclusive Tourer 2.0 HDi
Previous-
'97 Volvo V90
'05 Merc C320 CDI estate
'08 Volvo V50 T5 R-Design
'10 VW Golf 1.6 TDI estate
I'm having my n/s CV boot replaced tomorrow, how common is that?
I've already had the o/s one re attached.
Cheers
Cheers
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Never needed mine doing at all.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
Nor mine...
...so far!
...so far!
- (Donor 2021)
- My Cars: Citroen C5 2010 Exclusive 3.0 L V6 DTT
- x 4
Replaced front struts / shocks and lower control arms at 148,000 klms .
Replaced lower front suspension bushes at 172,000 klms .
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Front spring.
- My Cars: 2012 Citroen C5 VTR+ NAV 120kW 163bhp Diesel
Only have my 2012 X7 for 2 months, bought at auction.
Drove like a pig to my horror upon collection, largely fixed by a replacement lower rear engine mount which was completely worn out no doubt due to the dual mass flywheel gear change stresses.
I also replaced the battery but still getting the economy mode and sat nav/radio switches on/off several times after a cold start.
The flywheel, clutch and timing belt was changed by a previous owner.
- Gregor
Past members:
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
You should add, door hinges, radiator fan and paint peeling on the list.... It had to be a very "drunk day", when they assembled my "lemmon".
