C5 (X7) Component Failures /Faults / Replacements Poll
Post Reply
Which of the following failures/replacements (past & present) have you had on your C5 (X7)
A/C Compressor
19
4%
A/C Condenser
19
4%
Alternator
21
4%
BHI (Hydraulic Pump / Motor)
9
2%
Blown Air Module
3
1%
BSI
4
1%
Car Battery (<3 Years)
28
6%
Clutch (< 40k Miles)
5
1%
Clutch (40-80k Miles)
12
2%
Dual Mass Flywheel (<40k Miles)
3
1%
Dual Mass Flywheel (40-80k Miles)
12
2%
EGR Valve
20
4%
Electric Parking Brake
14
3%
Electric Window Regulator
37
7%
Engine Fuse Box
11
2%
Front Height Sensor
6
1%
Front Suspension Pipe
3
1%
Front Suspension Strut
45
9%
Head Unit/Audio/Sat Nav
14
3%
Heater Resistance Module
6
1%
MAF
4
1%
Manual Handbrake Cable
2
0%
Parking Sensor(s)
26
5%
Particulate Filter (FAP)
10
2%
Power Steering Pump
6
1%
Rear Height Sensor
16
3%
Rear Suspension Pipe
12
2%
Rear Suspension Strut
11
2%
Screen Wiper Motor
22
4%
Starter Motor
7
1%
Steering Rack
62
12%
Turbo
9
2%
Tyre Pressure Sensor(s)
18
4%
Vacuum Solenoid
4
1%
Total votes: 500
EDC5
My Cars: Citroen C5 RHR AM6
x 120
Re: C5 (X7) Component Failures /Faults / Replacements Poll
Post by EDC5 »
GiveMeABreak wrote: 03 Mar 2018, 11:03 That would be very interesting Elis if these can even be taken apart...
Well, it may be a one-way disassembly.... :lol:
I can cut away at the gaiter at least and see where the oil is coming from, I assume the seals at the top of the ram are what have failed.
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5741
Post by GiveMeABreak »
I'd be interested to see how they are sealed internally and what is the failing issue - is it the internal components of the ram that fails and allows he oil to leak into and out of the gaiter?
Sloppysod
My Cars: Citroens
1 x GS, 1 x GSX (Banger raced), 1 x GSA,
2 x CX Famililles, 1 x CX GTI,
BX, XM, Xantia, C5 Mk1,
C4 (Coupe), C4 (B7),
C5 (X7) - RIP April 2024
Renault
R4 Van
Fuego
Clio Campas
x 216
Post by Sloppysod »
Hi All,
I have been thinking about this, among other things, but what do you think of a Wikki page with a small photo of the problem showing the location of the part and or the tell-tale and 160 charecters or less of the symptoms and a link to an existing conversation/thread to help people check. And by clicking on the poll heading takes you to the wikki page?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Major interventions
C5 Steering rack @ 58,000 mi
4 discs & Pads @ 63,585 mi
2 (AM6) oil exchanges @ 58,876 & 72,378 mi
Lenny
My Cars: 1986 2cv Charleston
1986 2cv Special
2010 C5 2.0HDi Exclusive Tourer Auto
1992 VW Corrado VR6
1970 Vw Beetle
x 39
Post by Lenny »
I don't want to tempt fate but my X7 has been brilliant.
I don't 'do' modern cars really and was expecting to spend as much repairing it as my last company car cost (a BMW 120D Sport - hateful thing).
It's been 2 years and 20,000 miles now and I've forked out for an EGR valve (about £150ish I think) when I first got it, then one of the reversing sensors (about a tenner off Ebay and 5 mins to fit) about a year ago.
No leaks, no squeaks, nothing has broken or fell off. Not even had a bulb.
Maybe I've been lucky but the warranty I bought with the car 2 years back has thankfully been a waste of money.
Compared to that awful, unreliable, cramped, uncomfortable BMW this C5 is an absolute dream.
C15 Romahome White
CX 20 Polar White
x 5741
Well, 14 racks from the regular members here so far! That has to be the majority of X7 owners, closely followed by the front struts. This has been quite useful in building up a pattern.
jgra1
(Donor 2021)
My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong
x 39
Post by jgra1 »
hi Marc, the submit button is missing, but if you can throw me in for a rack I would appreciate that sometime (well, I don't really! :))
Also, mine has had handbrake performance issues in the past (including a locked actuator in the caliper) but as yet I have got through MOTs just..
so technically I haven't replaced the cable/motor - yet
J
justas
My Cars: C5 X7 Tourer 2HDI 120kW
Post by justas »
There definetally should be an automatic transmission valve body (Aisin AM6) in the list...
Jucas2
My Cars: Citroen C5 Tourer
Post by Jucas2 »
I had to replace Injector from my Citroen C5 Tourer 2011.
Not listed.
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2520
Post by Gibbo2286 »
Mike 'Filburt' one cause that's frequently not considered with outside edge tyre wear is the regularity of full lock turns i.e. do you stop outside your house then do a right about U turn every day to go back the way you came, this puts a lot of thrust on the outside edge of the nearside front tyre and rasps off the rubber quicker than you think.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
DHallworth
Donor 2023
My Cars:
x 125
Post by DHallworth »
I can now add my heater control panel to that list. I can't adjust the temperature on the drivers side any more. Passengers side works but the rotary knob on the drivers side feels different and no longer works.
Bloody car! Once this has been replaced, this car has cost more on maintenance then purchase in 2.5 years.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Donor 2023
My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5
x 2893
Post by bobins »
The driver's side heater knob on mine has started going intermittent as well. Can they be stripped and the electrics cleaned or is it just a case of replacing the whole unit ?
Sadly no longer a C5 owner :(
C15 Romahome White
CX 20 Polar White
x 5741
There aren't any diagrams for the internals Robin - it's another replacement module - however it will be worth attempting a DIY clean with some electrical contact cleaner. We have a problem with the temperature / timer 'jog dial' on our oven - you either get a small increment or it goes mad and jumps hours making fine tuning an art. I used some electrical cleaner a few years back and it improved it for a few weeks, but has not gone back to the same behaviour.
I suspect that it is just worn down and ultimately will need replacing. Note that being the driver's side it gets more use on a RHD so is likely to be the knob that goes first as it were.
£581.42 thereabouts, depending on trim colour new if the Bizone control unit - gulp!
osx
(Donor 2022)
Lexia Available: Yes
My Cars: GSA X
BX 1.6
C5 X7 Auto
C5 X7x2 Manual
x 15
Post by osx »
Snapped alternator belt at 130k. Hadn't been replaced. Not sure when it should have been replaced but glad I had road service assistance. 10 min job and £20.
C5 X7 Exclusive 2.0 HDi Auto
C15 Romahome White
CX 20 Polar White
x 5741
Mine did this 5 months ago or so, luckily the Elctro Power Steering system runs direct from the battery, so I had enough juice to drive 20 miles home and then to the garage to get it replaced. I gave the battery a well-deserved charge after that.
I did have my suspicions that the belt was levered off with a screwdriver after the A/C compressor was replaced at the main dealers - as I noticed that one day there was a little 'nick' in the edge of the belt. That no doubt is where is eventually tore across and ripped off.
renagade
My Cars: had:
2 citroen ds super 5
1 citroen ds pallas
1 citroen bx
1 citroen cx pallas
1 citroen dyan
1 citroen ami
1 citroen 2cv
2009 c5 x7 in Black 84k
2011 c5 x7 in Black Semi Auto on steel springs 76k
now
2011 c5 x7 1.6 e-hdi egs6 black 70k
x 10
Post by renagade »
2011 C5 X7 1.6 e-hdi egs6.
75k Gearbox hydraulic failure . Cost . £2000
86k Clutch failure Cost . £1500
I need to get rid or set fire to it . costing me to much money.
There are so many roads to travel but so little time, (Paul Cofield )
Post Reply
