C5 (X7) Component Failures /Faults / Replacements Poll
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: C5 (X7) Component Failures /Faults / Replacements Poll
Yes Paul, you can change your options. I’ve left it so that people can go back and edit if they missed something
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Voted on the battery, not sure that has any relevance to a C5x7...
Also, maybe add FRIP joints and Fan motor ?
Only other thing has been gearbox stop/park/select solenoid.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
The only thing on that list was the steering rack.
And the battery but it was more like 5 or 6 years old.
No FAP problem but the fluid did need topping up a tad early.
On top of that.
Aux belt pulley had to be replaced and the replacement was getting noisy when we sold it.
Recurring injector fault(s) which I never found the cause of.
Lots of suspension bushes and tracking which didn't seem to be able to stay aligned for very long.
DRL blew so I just turned them off - too much hassle to replace both with LEDs and too expensive to replace one with the genuine part.
Not the turbo but the air doser valve.
The end went missing off the dipstick.
Of all the Citroens I have owned it was by far the least reliable. Great car when it was running though.
On top of that.
- Sloppysod
- My Cars: Citroens
1 x GS, 1 x GSX (Banger raced), 1 x GSA,
2 x CX Famililles, 1 x CX GTI,
BX, XM, Xantia, C5 Mk1,
C4 (Coupe), C4 (B7),
C5 (X7) - RIP April 2024
Renault
R4 Van
Fuego
Clio Campas - x 216
Good idea - Being the sort of person I am, I am sitting here with a smile on my face , thinking my car is in a fairly good condition, rather than a sad face thinking oh-my god is that going to go next.................... but useful to know what to keep an eye out for.
I think it should be rolled out for other vehicles.
Possibly a big database, with some clever programming to differentiate between Marques & Models, one stop shop.
Stu
Major interventions
C5 Steering rack @ 58,000 mi
4 discs & Pads @ 63,585 mi
2 (AM6) oil exchanges @ 58,876 & 72,378 mi
Major interventions
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Thanks Stu - all entries welcomed, even from current DS5 owners
The current Poll facility is quite limited in that we cannot do more with it other than what is shown - I would like to have had a little more detail and analysis, but it's not possible with the built in Poll unfortunately.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
GiveMeABreak wrote: ↑01 Mar 2018, 22:30 Yes Paul, you can change your options. I’ve left it so that people can go back and edit if they missed something
Um, how do I do that?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Paul-R wrote: ↑02 Mar 2018, 14:02GiveMeABreak wrote: ↑01 Mar 2018, 22:30 Yes Paul, you can change your options. I’ve left it so that people can go back and edit if they missed something
Try it now Paul, by going to the Poll and seeing if the options are now active - let me know when you have updated your response. It looks like I have to manually override the permission in another location.
- Paul-R
- Donor 2023
Yep, that works now. The "Submit Vote" button is there again.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Thanks Paul. I've assumed you've hit the button now after correcting.
I suspect I'll have to do the same for David H so he can register his BHI as that's an important statistic.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
So as expected, the largest failure rate so far is the Steering rack, closely followed by the front suspension strut (which I am now having to get done on mine when it arrives from Poland) - but half the current Citroen price of £344
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2893
I know my front suspension strut will never fail like yours, Marc, as mine is on steel. But not to be outdone - I had a front coil spring go on it a year or two ago
Sadly no longer a C5 owner
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
True! But I can still drive with it as the leak is only slight at present - (not that I am at present), but I do wonder - If these C6 / X7 hydraulic struts don't have the front leak back pipes like the MK I & IIs, there has been suggestion that the strut gaiter just has extra seals / clamps to stop the oil leaking out - but without ever seeing one internally, I doubt it is this simple or we would all be investing in Jubilee clips to cure the problem....
I've added my faults which are the most common, but considering the mileage is now at 205k it's been the best car I have ever owned in over 30 years of motoring. It still doesn't rattle or squeak!
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
GiveMeABreak wrote: ↑02 Mar 2018, 17:31 True! But I can still drive with it as the leak is only slight at present - (not that I am at present), but I do wonder - If these C6 / X7 hydraulic struts don't have the front leak back pipes like the MK I & IIs, there has been suggestion that the strut gaiter just has extra seals / clamps to stop the oil leaking out - but without ever seeing one internally, I doubt it is this simple or we would all be investing in Jubilee clips to cure the problem....
I still have my failed strut lying on the floor of the garage, maybe I should get around to performing that autopsy I promised to see how it actually failed
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That would be very interesting Elis if these can even be taken apart...
