Citroen C5 X7 Windscreen Wipers
- My Cars: Citroen C5 tourer 2.0 hdi 2009
- x 5
Re: Citroen C5 X7 Windscreen Wipers
Yes I washed it, I didn't drove the car for about 2 weeks.
I fitted used ones.
Yes there was bad water signs on the old motors, I tried to open one and inside the electric part was ok but the other side there was like bad corrosion.
I fitted used ones.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Ok, thanks, I suspected water damage - the X7 seriously needs an oil and grease bath I think - too many components failing because of this!
Cheers for the video, doesn't look too difficult to replace!
My passenger side wiper isn't working, just lifts an inch or so when the right one sweeps the screen.
Im going to need a lexia/diagnostic to see if it is the left or a problem with the right stopping the left slave from working. Does that have to be done at a dealer or does anyone know of a place in Leeds that could diagnose?
TIA
TIA
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Anyone with Diagbox would be preferable, as generic readers may not have the detail.
- (Donor 2017)
- My Cars: Citroen C5 Tourer 1.6 eHDi VTR+NAV
- x 59
Nice video. Wish my battery came out that easy lol.
Had a diagnostic check which confirmed the passenger motor at fault. Citroen wanted £300+, got one off eBay for half that.....an hour in the rain to fit and all good now!
- petef
- My Cars: DS DS5, C4 Coupe, DS23 Pallas, Xantia Activa
- x 11
OK. Less than 4 months after voicing my concerns in this thread, the worst has happened. The wipers have stopped working completely. None of this one side still twitching stuff. Both sides completely dead. Fuse in BSM fine of course. Strangely my Lexia is unable to communicate with the wiper ECU whilst being able to talk to everything else. Any suggestions as to where I start? Mine is a 2009 model so I will try the Citroen dealer but my VIN doesn't seem to have been covered by the recall and I won't hold my breath.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Pete
They will simply replace the master wiper I suspect as that handles all the requests. I suspect if you have explored the fuses that it might be that it has just corroded internally as they do, but your was maybe a more total fail than a gradual one.
- petef
- x 11
Thanks Marc
Could you please remind me which side is the master? The lack of communication of the ECU with my Lexia perhaps suggests that it has failed. Is it integrated into the master motor assembly?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Pete - I believe on RHD it is the Driver side - see my post here:
viewtopic.php?f=3&t=54676&hilit=slave+ecu#p483220
- petef
- x 11
So eventually got wipers going again. Problem was that they had a lingering death with several miracle recoveries. When they were working they were fine, no twitching of one blade or anything daft and full communication with the wiper ecu with the Lexia and no fault diagnosed. However when they stopped working there was no communication and hence no diagnosis. Tried replacing the 'Master' drivers side motor with a known good one. All was well........for a short time and then they packed up again. Must have been another short lived miracle. Eventually tried a replacement for the passenger side with another known good one and ...voila...all is well again. Moral of the story is don't go with your gut feeling - I was convinced the RHS 'Master' unit was faulty but eventually found it was the LHS 'Slave' than was shot.
BTW new ones would appear to be cheaper than Citroen here - https://www.allcarpartsfast.co.uk/peuge ... per-motor/ although I haven't used them - I got second hand ones.
- My Cars: '12 Citroen C5 X7 HDI 160 Tourer Exclusive
'04 Citroen C5 Estate VTR+
'95 Citroen Bx 19D Converted to run on Vegi oil (Deceased)
'95 Citroen AX 15D (Deceased)
'92 Citroen Bx 17D (Deceased)
'89 Citroen Bx 1.4 Petrol (Deceased) - x 4
My wipers stopped working new years eve 2 years ago in a storm.
Managed to get home and took c5 into local citroen garage who diagnosed the RHD drivers side unit needed replacing.
They also advised to replace the passanger unit as they said it wood soon fail and would have to pay for labour twice.
I said if it stopped working in the next 12 months i would just order a passanger side unit and fit it myself.
2 years on and still working.
- Michel
- My Cars: Some cars and a motorbike
- x 659
As do many others, including the Vauxhall Meriva - I had to change the whole assembly on one of those, cost me £20 secondhand including the motor.
Recently did the same on my neighbour's 08 Plate Passat as the linkage had sheared. £15 for the whole linkage, including motor off eBay, s/h.
I'll not be buying a C5 X7 of any sort any time soon, that's for sure.
'13 3008 1.6 HDi GripControl - x 984
C4GP has separate linked motors
If you put them in service position and then watch them whilst they park back to normal, you will see that they don't move in sycn.....
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I know the following do too:
C6
DS5
3008
407
I'm trying to see the reasoning behind it, when even on the newly badged DS range, only the DS5 has it.
C6
DS5
3008
407
